A12 EFI Intake
From Cambria, California
Looks like nice work, but seems to be a round port intake vs. the preferred oval port intake.
http://www.ebay.com/itm/Datsun-A1200- ... :WIcAAOSwbdpWa2AS&vxp=mtr
Posted on: 2016/2/25 18:30
Re: A12 EFI Intake
From Creswell, Oregon USA
I have a treat in the works for EFI... I have the material in the my current work load. Stay tuned for a new EFI Mani.
Posted on: 2016/2/25 20:22
An idea doesn't work unless you do.
Instagram @MD_Machine
Parler @MDMachine
Re: A12 EFI Intake
Nice price for the whole setup - only $1500
Round port would be nicer for tooling around town and blasting down the highway at 80 mph. Don't wanna be turning more then 6000 RPM in any case
I can't help thinking that these sidedraft EFI kits look more in character with our classics than a modern-looking plenum manifold
jpg  ITB kit.jpg (57.00 KB)
174_56cf7ea1cd3c4.jpg 960X641 px
jpg  EFI.jpg (58.76 KB)
174_56cf7eacb314d.jpg 960X639 px
Posted on: 2016/2/25 22:23
Re: A12 EFI Intake
Am I the only one that thinks that's an oval port, not round?
Example of another oval port taken from the same angle.
Round port from about the same angle.
If you were really curious you could just shoot him a quick message through eBay.
Posted on: 2016/2/25 23:30
Re: A12 EFI Intake
I think you are right ... it won't bolt to an A12 with that flange
Posted on: 2016/2/26 0:16
Re: A12 EFI Intake
round port heads even smaller port heads can make good power but engine
needs to rev high more like a motorbike with little power down low and
have long rod stroke ratio with suitably designed camshaft.
I feel old fashioned but for the cost of this unit ecu and dyno I prefer
to run quad bike carb setup or even a 36/36 weber with Soufrikan manifold
http://manifolds.co.za/index.php?opti ... =item&item_id=50&Itemid=2
Matthew is your mani multi piece to allow for either sep plenum & itbs
Would be handy for some kind of angled primary inlets like below for extra room
or to clear some of the issues with LHS driven dattos on your side of the pond
e.g
Posted on: 2016/2/26 2:31
Re: A12 EFI Intake
Twin TB's or A Bolt on Plenum Single TB.
Posted on: 2016/2/26 3:20
Parler @MDMachine
Re: A12 EFI Intake
The one for sale on eBay is a South Africa manifold, it says right on it Rowland M030
LHD cars work with ITBs
Sure there's no room for a brake booster, but we aren't little old ladies
Posted on: 2016/2/26 3:53
Re: A12 EFI Intake
My mani's will be 107mm from head side to TB mount.
Posted on: 2016/2/26 4:24
Parler @MDMachine
Re: A12 EFI Intake
Is that shorter or longer than a typical weber manifold?
Posted on: 2016/2/26 4:26
