Swapped A14 into 1200 air cleaner wont fit.
I just bolted a A14 into my 1200 coupe. Both the stock 1200 and b210 air cleaner will not fit under the hood. Is there a low profile air cleaner that I can use?
Posted on: 2016/4/17 7:44
Re: Swapped A14 into 1200 air cleaner wont fit.
Quite a regular
From Sydney
Try: http://www.weberperformance.com.au/index.php?cPath=36_281_285
How have you mounted the engine? Using a late crossmember and engine brackets? I don't see why the stock setup wouldn't fit.
Posted on: 2016/4/17 9:38
From Western Australia
Nissan/Datsun Vanette inlet manifold lowers the carby and creates more than enough room.
Posted on: 2016/4/17 12:48
1200 Sedan SR17VE + TURBO (Borg Warner twin scroll), 6 Speed, Brembos, Autronic SM4 ...coming together slowly.
Stanza rally car mostly ex works = FIA head, 50mm Mikunis, option one, works diff, 4 pot FIA calipers and vented disc all round, enkies, h...
From Perth
Big blocks are taller
Maybe a Vanette once
Posted on: 2016/4/18 11:27
From Nations Capital, Australia
I have a Vannette one that I bought for that reason.
I still have it if your interested. Shoot me a pm.
Posted on: 2016/4/18 13:56
If you fit an A14 air cleaner, it will fit under the 1200 bonnet. I've had two A14 and an A15 in 1200s
Posted on: 2016/4/19 7:03
