« 1 2 (3) 4 »
Re: CNC A series Oval Flange
From 'Merica
Those injector bosses are machined into the flange adapter. It's all one piece.
This particular manifold came from a 1995 Mercury Tracer (USA). It was rated at 92hp 100tq.
The runners are 32mm ID 38mm OD mandrel bent tubing and are about 29 cm long after I cut them off and cleaned them up. The plenum is 54mm ID 60mm OD tubing with a stamped cap on one end. The stock throttle body is ~40mm.
It's a fantastic starting point especially since I only paid $24 at a local salvage yard.
Posted on: 2016/5/17 13:23
From Lyngby, Denmark
Damm that looks good!
LOVE your rail/holder :O what is the length between the flange and the rail?
Great design, would like to make a set of my own... are you mounting them with one long bolt through the middle? or do you screw it into to flange?
Posted on: 2016/5/18 16:45
Thread related pics i came across on FB a while back
Cant seem to get the user who posted them...il keep checking
jpg  IMG_2017.JPG (106.37 KB)
15239_573d411eba6f6.jpg 560X420 px
jpg  IMG_2018.JPG (105.25 KB)
15239_573d412da11cd.jpg 560X420 px
jpg  IMG_2019.JPG (104.43 KB)
15239_573d4134cca74.jpg 560X420 px
jpg  IMG_2020.JPG (117.22 KB)
15239_573d413d58047.jpg 560X420 px
Posted on: 2016/5/19 5:30
From 'Merica
38.1mm (1-1/2"), which is strange since the injector is stock for a 2004 Honda Civic Si. It's the same length as a "GM LS2" injector.
jpg  IMG_20160519_065959572.jpg (174.44 KB)
18181_573d9e7766f2d.jpg 617X600 px
jpg  IMG_20160519_070005752.jpg (171.02 KB)
18181_573d9e9377043.jpg 784X556 px
Posted on: 2016/5/19 12:08
From WA perth
you should,nt rap your manifold it will crack over time , get it ceramic coated to contain the heat in the pipes. I have done mine and works well
Posted on: 2016/5/19 12:33
From Adelaide
This is roughly what I have in mind but I might change my mind again before I get to building it. Depends on where I land with the turbo exhaust manifold. I do like the idea of keeping as much of it away from the turbo heat as possible. Even the heat off the headers/ extractors is significant.
jpg  A15 mani view 5.jpg (125.40 KB)
11744_573ea3bd9bb2f.jpg 1408X627 px
Posted on: 2016/5/20 6:42
1200 Coupe A15E - ITB
Lamb Daiquiri - a man's cocktail!
A12grunt, nice design of inj. spacer! Great idéa. Simple too.
Posted on: 2016/5/20 23:38
From Adelaide
Here's some pics of the exhaust manifold and how I would like to see it go together. I'll probably have to change the design a bit as I figure out how I'm going to make it but the main ideas are there.
jpg  AserTex view 1.jpg (113.13 KB)
11744_574105a372f15.jpg 1269X759 px
jpg  AserTex view 2.jpg (106.95 KB)
11744_574105b29eb6f.jpg 946X816 px
jpg  AserTex view 3.jpg (47.91 KB)
11744_574105bbb909c.jpg 938X276 px
jpg  Turbo assy.jpg (100.97 KB)
11744_574105c7408b3.jpg 1015X781 px
Posted on: 2016/5/22 2:06
From 'Merica
I like the design but I have no idea how you'd actually make one short of investment casting or lost wax/foam casting.
Posted on: 2016/5/26 13:34
From Adelaide
I've been thinking about it, I think I can approximate it with tube and sheet metal. Maybe next week I'll get some more time on it. I looked into 3D printing it but I think it's cost prohibitive (like 2-4k) which is a bit more than I'd be willing to spend. Traditional sand casting or wax would both work but I can't do that. I could probably print up moulds.
Anyway, I'll think about it a bit more.
Posted on: 2016/5/26 22:51
« 1 2 (3) 4 »
