CLUTCH QUESTION
From Goulburn NSW
Hey guy's
I have a question,im planning on running a fully built Os giken sr20det with ca18det bell housing gearbox.Do I run a sr20 clutch or ca18 clutch?ca18 motor.
Posted on: 2016/6/17 2:56
Re: CLUTCH QUESTION
From Snohomish, WA USA
What's your flywheel? SR20 or CA18. Sizes I believe are different. That will determine your clutch.
Posted on: 2016/6/17 4:17
'73 2 Door Sedan
Crower Stage 3 Cams/SS Valves
Forge CP Pistons/ Eagle Rods
Ford 8.8/Mini Spool/4.11
Re: CLUTCH QUESTION
From Narellan,Sydney
How you going with this car mcdat.nearly finished?
Posted on: 2016/6/18 23:06
All stainless steel-mild steel Sheetmetal and tube work
All types of welding
Custom metal polishing
BSA custom fabrication 0415 904 474
Re: CLUTCH QUESTION
From Goulburn NSW
Hey Datrotor,
no where near it still buying all the best parts.Only got the crank,pistons and conrods left to buy then the motor is ready to be built.Then will start buying all my maddat front end,then of to get tubbed,9" and 4 link.So a lot to do still.
Posted on: 2016/6/19 1:23
Re: CLUTCH QUESTION
What have you been doing the last couple years lol nah it all takes time mate
Posted on: 2016/6/19 3:57
Re: CLUTCH QUESTION
From Adelaide
MADDAT can cut you down a S13 irs rear to the
same track as a 1200.
I use a R200 center in mine.
Better handling than a beam axle and more than
strong enough for a SR20 turbo.
Posted on: 2016/6/28 11:05
Go Fast,
Or Go Home.
Re: CLUTCH QUESTION
If your going a fully built ca why have you gone an sr20 box instead of the rb25box?
And you'd be better off going custom fly/clutch setup from npc/Jim berry ect
Plus you will need this before you build a motor so they can balance it all you need all the motor parts too for the best results inc balancer ect
Posted on: 2016/6/28 11:59
Car free
