« 1 (2)
Re: 1200 vs 1000 (weight difference for racing)
Adelaide is too far for us to work out anything.
I think those comparisons of weight vs the motorcyle motors aren't like for like. The bike motor weights probably includes the gearbox.
Stick with the transverse leaf spring design. You can get them to work and the weight is as low as you can go.
When Holden and Nissan were sharing their vehicles and power trains were there any Holden motors that could be fitted? I'm thinking of the Astra turbo motors. I've seen Geminis with Toyota SGE turbo motors because the NA version was fitted to the Apollos
Posted on: 2016/6/29 9:45
From Perth
Posted on: 2016/6/29 12:34
ma09ert is perfect but also hard to beat an A12 with mazda miata head or well setup turbo
Posted on: 2016/6/29 15:38
Edited by D on 2016/7/1 0:33:52
Dvr1000 where r u located? Will likely be heading down the east coast for a camping trip and will be in Brisbane a few times in the coming months
What is the engine weight of the ma09ert? Wiki shows 112kg, much heavier then the cr13de plus because it's turbo the displacement is multiplied by 1.7 and a restrictor has to be used (size depends on class). It's also only 8 valves and single cam, potentially limiting power/mid range torque depending on cam selection/valve sizing
Posted on: 2016/6/30 17:18
I think that weight is with the transaxle?
Posted on: 2016/7/1 0:34
If so could be a contender, will look into it further.
If anyone else has any ideas post them up.
Posted on: 2016/7/1 2:41
Sydney
Posted on: 2016/7/1 3:17
From Perth
Posted on: 2016/7/1 13:08
seeing as this has turned into an engine thread, i'll start a new topic to discuss it.
Hopefully it may get some more input
Posted on: 2016/7/4 5:22
« 1 (2)
