« 1 ... 9 10 11 (12)
Re: Nicks datsun 1200 ute
From Kelmscott Western Australia
So got all the wiring harness all done got the egi /factory/ aircon all into one hole harness was alot of hours put into it and its a mint job
I been playing with the motor i moved the coolant temp sensor to a blank face on the gx head when i got the head done i had the coolant holes welded up
I changed the camshaft to the specs of the motor is
A14 egi
Nos gx / egi cam
40thou oversize pistons
Gx head (been sitting on the shelf since the mid 80s)
Posted on: 2016/7/24 12:18
71 Datsun 1200 ute with A14 fuel injection
59 Morris minor ute with A15 fuel injected with intercooled Sc12 supercharger
only been since 2016 thought I put up the finish article up
jpg  datsun.jpg (186.86 KB)
13822_5b4355eb6114a.jpg 1024X683 px
jpg  datsun2.jpg (190.72 KB)
13822_5b4355f85e977.jpg 1024X683 px
Posted on: 2018/7/9 13:33
From Mordialloc Victoria 3195
NICE - DID YOU PUT THE COOLANT SENSOR ON BLANK SPOT ON THE RHS OF THE HEAD , JUST BELOW
THE THERMOSTAT HOUSING?
Posted on: 2018/7/9 22:25
keep it simple
Blank of gx head was drilled and tap out on lhs on manifold side
Posted on: 2018/7/11 13:44
From Hawaii, USA
One of the nicest fuel injection retrofits ever! Good work. Is that aircon I see?
There is the ECU coolant temperature sensor (typical Nissan fuel injection type)
This was on the stock EGI manifold near the last runner. Same as the 280Z/280ZX unit
some later 1970s-1980s head have a sensor boss here
There is the temp sender for dash Temp -- EGI used same one as Datsun 1200 and regular B310 Sunny
And a cooling temp sensor (not part of a stock EGI motor) for example this was used on some B310 with electric cooling fan -- fitted to the lower radiator hose
jpg  13822_5b4355f85e977.jpg (65.88 KB)
174_5b493e51a79f4.jpg 400X300 px
Posted on: 2018/7/14 0:57
Yes air con
Posted on: 2018/7/14 6:07
thought i send a photo after a while
jpg  ute 1.jpg (34.54 KB)
13822_61c6af163977d.jpg 408X306 px
jpg  ute2.jpg (108.97 KB)
13822_61c6af42de663.jpg 816X612 px
Posted on: 12/25 5:42
Be a update
So now he ute has now a dual fuel tanks with total of 75 litres with a dual fuel solenoid on a switch to change over in the cab for long range driving
Also in the works a toyota t50 5 speed not a dellows clutch setup as bit flimsy for my taste made my own
With tail shaft also made be ready to go in
Posted on: 2/5 7:43
From Hawaii, USA
75 litres!
And ute so shiny. Those Cibie 10DE look good
Posted on: 2/10 2:31
Any dyno figures after installing the EFI?
Posted on: 3/5 18:27
