« 1 ... 70 71 72 (73) 74 75 76 ... 96 »
Re: Super Bee KA24DR Mod
From Snohomish, WA USA
Thanks Dave. Carbs show up Monday so I will be working on it as soon as they arrive.
Posted on: 2016/6/18 6:19
'73 2 Door Sedan
Crower Stage 3 Cams/SS Valves
Forge CP Pistons/ Eagle Rods
Ford 8.8/Mini Spool/4.11
Happy Father's Day.
Another good burnout picture.
Received the Weber 38's in the mail yesterday. Will be working on those a little bit today.
jpg  FB_IMG_1466319947838.jpg (26.30 KB)
39_5766b250abbe1.jpg 600X400 px
Posted on: 2016/6/19 15:57
'73 2 Door Sedan
Well that didn't take long. Now the tuning process starts all over again. These carbs should be easier. Already have them at a good idle.
Posted on: 2016/6/19 21:51
Edited by datsa73 on 2016/6/19 22:57:22
'73 2 Door Sedan
Well I'm not sure what happened but I thought I had these carbs dialed in after running a little test and tunes on the back road around my house.
Took the car to the track Sunday and had major fuel flooding issues. Only got two runs in with a good time of 6.34 but was having issues off the starts.
I would say my mistake was ordering a new fuel pressure regulator that regulates between 4.5-9 psi. The 4.5 psi was a little to much for the Weber 38's. I should have been thinking more on the fly and fixed the problem but I just took the car home. After getting home, I took the spring out of the regulator and snipped a full ring out of the cone shaped spring, reshapped the spring and was able to dial in 3 psi. Carbs are running a lot better. Now I just have to wait 2 more weeks for the next race.
Now after running out of gas yesterday and being stranded on the side of the road until my girlfriend could bring me gas, I'm now trying to decide if I want to spend $130 on a computer that converts gas gauge ohms to dissimiler fuel tank sending unit ohms.
FuelLink SN34
Currently I have a 240/33 gauge and a 0/90 sending unit. Cheaper option is to just get a new sender but I don't feel like dealing with the tank.
Just another project.
Well I know now the car gets about 12 mpg.
Posted on: 2016/8/2 18:38
'73 2 Door Sedan
From Adelaide
If you put 33ohms in line with the sender at least you'll know when it's at each extreme, you just won't get the full range on the gauge.
Posted on: 2016/8/2 22:10
1200 Coupe A15E - ITB
Lamb Daiquiri - a man's cocktail!
Thanks.
I had previously tried resistor. I think I'll give it another shot today since I have nothing else to do.
Posted on: 2016/8/3 2:42
'73 2 Door Sedan
Well it was cheaper and easier to just buy a new gauge.
Posted on: 2016/8/4 7:27
'73 2 Door Sedan
Best way to do it!
Posted on: 2016/8/4 7:30
Thanks Dave. I have mostly all Sunpro gauges because I like the look, they work and are inexpensive. Was able to fine a VDO gauge on Summit Racing that's the same black with orange/red look. Should be here today. Summits always been quick with shipping. Next race is August 14th. I should be ready by then.
Posted on: 2016/8/4 17:01
'73 2 Door Sedan
Was out the other day and stopped by a friend's house. Of course the car is running good but that's because I'm not at the track.
Will be out there Sunday to give these Weber 38's another shot.
jpg  IMG_20160810_203944.jpg (162.67 KB)
39_57abf556a7e00.jpg 999X565 px
Posted on: 2016/8/11 4:47
'73 2 Door Sedan
