12mm lift is big. The biggest cam Nissan competition sold was 12.2mm (Nissan 99996-H1030 by Electromotive). It was one step up from their 82 cam
having some trouble revving it pass 8200rpm ... Any suggestions???
That's right around where the cam's peak power is made, but should rev higher with reduced power
Most common cause of not be able to rev is valve float
* Spring pressure too weak to rev higher
* Coil bind at high RPM. Dual and triple coil designs are to help prevent this
The Nissan/Electromotive springs should have an installed height of 1.61" and a seat pressure of 130 lbs/in
The VS39 springs are a lot lower pressure, and call for shorter height. Are you running some kind of spacer under the springs?
Ford VS39 specs
VS39 DOUBLE
* 34.0mm installed height (1.34")
* 90 lbs installed pressure
* 21.0mm minimum height (0.84")
* 250 lbs maximum pressure
* 20.0mm coil bind
* 16.0mm I.D.
* 28.8mm O.D.
* 13.0mm maximum lift
Nissan Competition also called for an "oversize cam follower" with the Electromotive cams. I'm guessing that had to do with longevity/durability. They recommended
13231-78201 which is a stock lifter taken from the Nissan R16 engine and are still sold by Nissan
