« 1 ... 44 45 46 (47) 48 49 »
Re: Turbo EFI A12 for under $1200. Discussion thread
not till the scum in parliament stop ruining the country ;p
Posted on: 2016/9/7 0:16
hey Simon I am just wondering is there an up to date list of sensor part numbers etc, as I am seriously considering haven a crack and this DIY project. Also is there some data as to what to set micro squirt for a base line non turbo and turbo ecu settings? instead of starting with no data (or is this unit self tune?) this may have been mention before but haven come across this yet.
Cheers nick
Posted on: 2016/11/14 2:41
Not too shy to talk
Who's got the base map supporting these mods for micro squirt?
Posted on: 2017/6/25 13:03
From Mordialloc Victoria 3195
I have but its for 4 injectors on E85.
Don't ask me how to send you the file - I have no idea unless you do :)
Posted on: 2017/6/26 3:48
keep it simple
From Creswell, Oregon USA
Whats new in Simon's world?
Posted on: 2017/6/28 18:32
An idea doesn't work unless you do.
Instagram @MD_Machine
Parler @MDMachine
well that was an interesting read.
what was the end result of this build Simon?
is the file for the ecu available to download?
great work.
Posted on: 2019/4/7 11:58
For those interested in what happened.....
The engine is currently in my 1200 ute. I fitted it with a draw through carb and had it up and running - poorly. Not being able to find anyone to tune it here it sits in the garage.
I am contemplating putting some sort of EFI on it, either a weber throttle body type unit or strangely enough was thinking about a 2 injector setup like the one pictured on the previous page with a Haltech or something. This winter it will be running With injection!
JD
Posted on: 2019/4/10 13:03
Most guys now are helping criminal Zuckerberg`s Bookface these days
good luck getting it tuned, wont be easy without the setups he had
Posted on: 2019/4/11 4:36
Edited by D on 2019/4/11 12:53:04
Shouldn't be that hard- what sort of draw through carb are you using?
Where have you set the timing?
Posted on: 2019/4/11 4:50
I hate the big social criminal sites.
Posted on: 2019/4/11 12:59
Parler @MDMachine
