« 1 (2) 3 4 5 ... 10 »
Re: Master Cylinder Brace
From sydney australia
My comment would only apply to a right hand drive car, but you could use another clutch pedal to get the extension for the master cylinder, plus it would move in the right direction. For the lefty sitters, you have hydraulic clutches, so it doesn't work for you. Unless you can convince a couple of us to swap clutch pedals. Just a thought, must be the Vegemite kicking in.
Posted on: 2016/9/17 10:31
From Creswell, Oregon USA
Rally,
I will try to make the kit as bolt-in as possible. Its very helpful that the pedal rack is the way it is, so if some drilling needs to be done it wouldn't be impossible.
Luigi,
Stay tuned.
Posted on: 2016/9/17 18:48
An idea doesn't work unless you do.
Instagram @MD_Machine
Parler @MDMachine
From Lisbon
Im all ears, with twin carbs i have no clearance to bmc, im expecting news from you
Thanks
Luis
Posted on: 2016/9/17 21:17
From Lisbon
With your brace, what changes i must do?
Posted on: 2016/9/18 15:03
Edited by Luigi on 2016/9/18 16:40:53
Luigi,
The Master Cylinder Brace is just a support for the end of the Master Cylinder if left in the engine compartment. Only alterations needed is holes drilled for bolts.
The internal remote MC kit is a different item all together.
Posted on: 2016/9/18 19:02
Parler @MDMachine
From Lisbon
How can i link the master cylinder on compartment to the brake pedal, how i can gain clearance with your brace?
Many thanks
Luis
Posted on: 2016/9/18 20:44
The Brace has nothing to do with clearing up space.
the current topic albeit sidetracked into a discussion about creating a kit that will allow you to relocate the master cylinder inside the passenger compartment. Like what had been posted on page one. Only no weld required.
This way you can clear up the space for your carburetors.
I am also making braces for cars that are not looking to do this relocation.
Posted on: 2016/9/19 6:30
From Lisbon
Hi!
I want relocate the master cylinder inside the passenger compartment or a equivalente BMC one. Master cylinder besides horn carbs is an optionwith 1cm of clearance, its to much close.
Man i just want brakes. At the moment i dont have any brakes If you please inform me about a solution i need to put the car on the road
Many thanks on advance
Luis
Posted on: 2016/9/19 13:57
Edited by Luigi on 2016/9/19 15:13:44
Edited by Luigi on 2016/9/19 20:57:36
1 cm is enough clearance
Posted on: 2016/9/20 3:04
Here is the BMC brace.
Posted on: 2016/9/20 3:12
Parler @MDMachine
