« 1 2 3 (4) 5 6 7 ... 10 »
Re: Master Cylinder Brace
From Creswell, Oregon USA
Mount Bracket for the stock TOKICO master cylinder.
Some drilling in the rack required.
Posted on: 2016/9/20 23:25
An idea doesn't work unless you do.
Instagram @MD_Machine
Parler @MDMachine
Does this brace bolt to the firewall? And what is the "rack"?
Posted on: 2016/9/21 2:40
Sorry "rack" being the sheet metal box the the pedals are attached to.
I will post images as I do the install.
Posted on: 2016/9/21 3:36
Nissan calls that the "Pedal and Steering Post Bracket", though most here call it the "pedal box"
46570-H1600 LHD ASSY-BRACKET PEDAL & STEERING POST
Unfortunately mounting the M/C on top of the bracket means you can't use the stock dash assembly. Do you think there is room beside the Bracket, i.e. next to where the flasher can is (on either side?)
Posted on: 2016/9/21 4:14
From Las Vegas USA
For the record my dashboard is long gone; I have flat aluminum sheet cover on a horizontal plane at the lower edge of the windshield that bolts to the vertical gauge panel.
I'm assuming the flat vertical face will butt up against the vertical hangers that hold the pedal box up?
Tom
Posted on: 2016/9/21 4:43
This setup was intended for cars that have a sheet metal dash.
The mounting plate in the photo above will butt up against the vertical sheet metal mounts that hold up the pedal box. It has 3 M8 X 1.25 threaded holes that will require through holes to be drilled on the pedal box. 2 horizontal holes for the ears on either side of the mount plate and 1 vertical under the u shaped cutout at the bottom. You can see the boss to the right of the MC mount profile.
This kit will look just like this
I am still exploring where best to place mounting holes for the MC mount plate.
Would the dash fit with one of these? Looking at the pedal box and having remote brake fluid reservoirs. The BMC can be located behind the factory dash
Posted on: 2016/9/21 5:39
Edited by Mattndew76 on 2016/9/21 5:57:06
Edited by Mattndew76 on 2016/9/21 6:05:07
Edited by Mattndew76 on 2016/9/21 6:06:53
Parler @MDMachine
Re: Master Cylinder Brace and Remote BMC setup.
Interesting stuff here, I like the bolt on pedal bit too very interesting
Posted on: 2016/9/21 21:57
Car free
From Las Vegas USA
A common thing I've seen on race cars is the remote reservoirs actually bolted to the dashboard essentially where radio would be but mounted in such a way that it's still higher than the M/C.
As Dave pointed out there are stock Datsun remote reservoirs, those could be mounted in various locations. In my case I would simply use a removable panel to gain access to the reservoirs.
Tom
Posted on: 2016/9/22 4:51
I started on the Lever today.
Posted on: 2016/9/22 6:22
Parler @MDMachine
From Lisbon
Nice work.
Im expecting to assemmbly it on my car, with your future brake mount support with two 5/8 brake cylinders and remote reservoirs
Posted on: 2016/9/22 9:22
