« 1 ... 4 5 6 (7) 8 9 10 »
Re: Master Cylinder Brace and Remote BMC setup.
From Lisbon
Hi!
To finish the project you will need to buy a balance bar correct?
Posted on: 2016/10/1 21:35
From Creswell, Oregon USA
Correct. I need to buy the balance bar to have the ability to get the layout exactly correct.
here is the rough Prototype of the Dual pedal lever.
Posted on: 2016/10/1 23:16
An idea doesn't work unless you do.
Instagram @MD_Machine
Parler @MDMachine
From Western Australia
Looks great.
I"m very interested in a dual cylinder/balance bar arrangement.
However,
Are you likely to develop a brake and clutch triple cylinder/balance bar arrangement (2 x brake master cylinder and 1 x clutch master cylinder) for those of us who run hydraulic clutch?
Posted on: 2016/10/2 0:21
1200 Sedan SR17VE + TURBO (Borg Warner twin scroll), 6 Speed, Brembos, Autronic SM4 ...coming together slowly.
Stanza rally car mostly ex works = FIA head, 50mm Mikunis, option one, works diff, 4 pot FIA calipers and vented disc all round, enkies, h...
fiasss wrote:
Looks great.
However,
You would just use the Dual mount and run a Billet Clutch lever, and a Billet Brake lever.
For the brake side you either use the TOKICO with remote rez caps (modeified push bar), or this Wilwood
http://www.wilwood.com/MasterCylinder ... Prod.aspx?itemno=260-7563
For the Clutch side you get a Wilwood 5/8's MC, or use the factory CMC (push bar mod needed). No balance bar needed for the brakes.
I am beginning to see the Wilwood stuff as the best option because you can get adjustable push rods. For the TOKICO stuff you will have to find a source that supplies one..I haven't found one yet.
Posted on: 2016/10/2 2:57
From Lisbon
Hi!
In my case, before i installed twin carbs i had 11/16 brake master cylinder to front brake discs and rear brake drums and i have hidraulic clutch too..
Now i have S13 front brake disc to replace the standard ones.
All i want is breakes to stop the car (at the moment i dont have) and get clearance on engine compartment to put horns and filters on carbs.
Let me know about dual willwood brake master cylinders to fit under my car dash, let me know if you will buy the balance bar?
Thanks
Luis
jpg  14218320_1315536825130703_1184304722_n.jpg (92.09 KB)
6267_57f0bcec6bf94.jpg 960X720 px
Posted on: 2016/10/2 8:43
Edited by Luigi on 2016/10/2 9:09:55
Edited by Luigi on 2016/10/2 12:17:31
Edited by Luigi on 2016/10/2 12:20:58
Hi Mathew,
Sorry but you missed point I was trying to make.
I want to run 3 X under dash master cylinders.
I require a hydraulic clutch and a brake balance set-up with dual brake master cylinders.
Thanks
Posted on: 2016/10/2 16:22
fiasss wrote:
Hi Mathew,
Thanks
No I got what you meant.
There might be a way to triple mount in the space I am currently working on, but I have to do way more than I am now. I can design a system like what you want, but I would have to do away with the factory pedal box and make a whole new one.
You can achieve the same purpose of the triple system just by using a proportioning valve with a 50/50 master cylinder.
If you really really want a triple system I can make you one though. I can figure out how to squeeze everything in.
If this is a for sure need and you want to spend the $$ we probably need to work on a set price and deposit.
Posted on: 2016/10/2 19:06
Picked up material to start the Dual mount kit.
Posted on: 2016/10/4 1:05
Parler @MDMachine
From Lisbon
OK!
Post pictures.... TO SEE THE GOOD JOB of your mount plate and see how is easy install twin carb with horns and filters on LHD Datsun 1200..
Posted on: 2016/10/4 9:14
From Lisbon
hI!
I ve order two 5/8 Gs Wilwood brake master, but i dont if the brake pedal becomes too harder
What do you think?
Thanks
Luis
Posted on: 2016/10/6 10:32
