Browsing this Thread:   3 Anonymous Users
« 1 ... 74 75 76 (77) 78 79 80 ... 97 »
Re: Super Bee KA24DR Mod
From Snohomish, WA USA
Nope. Not going to bore it out. Going to keep it the same. I believe I'm already 20 over.
Posted on: 2016/12/10 20:24
'73 2 Door Sedan
Crower Stage 3 Cams/SS Valves
Forge CP Pistons/ Eagle Rods
Ford 8.8/Mini Spool/4.11
Still waiting on the machine shop. That's always the hold up. Engines can be tore down and rebuilt in hours. Machine shops take days when you're waiting for your turn. Block came out of the tank Friday so machining should be started. Told Bill I'd leave him alone and call him Monday. He wants specs on the new pistons so I have to call Arias on Monday. With Boost and Nitrous he's recommending room for expansion on the pistons to the cylinder walls. All engine brackets and parts are cleaned and ready. Just need measurements
For pistons, rings and bearings.
Got my oil filter relocation kit as well. Prior, I had to pull the radiator, supercharger and carbs to change the oil.
Not anymore. Will be changing it more frequently.
Posted on: 2016/12/18 18:58
'73 2 Door Sedan
teflon side coated slugs help alot with bore walls on big stroke motors
common practice by all manufacturers using 89mm+ strokes
Posted on: 2016/12/19 2:46
Bill does his own coating but has never done it for anyone else. Most likely he won't do it for me. He does not want to be liable.
I have to call Arias tomorrow and get some numbers.
Posted on: 2016/12/19 3:18
'73 2 Door Sedan
Got my measurements so new Arias Forged Pistons and King Racing Bearings on order. Talked with Total Seal and they will make me a set of Gapless Top Rings.
Bills working on the head now. Still need to order a Cometic MLS upper head gasket kit.
Should have this engine back together around the first of the year as long as I can get the rings back from Total Seal.
I really didn't have to tear this engine apart, it was running fine but I'm glad I did. Didn't realize how much I worked the motor and really wore it out. It's the cost of racing.
Posted on: 2016/12/20 16:53
'73 2 Door Sedan
Now I'm into new intake and exhaust valves. Heads apart now and stock valves are two worn to use. So I'm into this more and more. I ordered a set of Supertech stainless steal valves and dual springs. Going to have a really built motor when this is done.
Posted on: 2016/12/22 21:46
Edited by datsa73 on 2016/12/23 4:33:07
'73 2 Door Sedan
Happy Holidays.
If you by your own gift, you get what you want.
jpg  IMG_20161225_124625.jpg (55.53 KB)
39_5860307001db6.jpg 700X393 px
Posted on: 2016/12/25 20:49
'73 2 Door Sedan
Well I'm almost $2k just in new parts on this motor and it was running just fine when I pulled it. Just ordered a timing chain kit and oil pump gears. I just mailed my pistons rings to Total Seal so they can make me Gapless top rings and Napier second rings.
Machine shop is finishing block and rebuilding the head installing the Supertech stainless valves and dual springs.
Maybe my HP potential will increase. I sure as hell hope so.
Posted on: 2016/12/29 3:11
'73 2 Door Sedan
SuperTech stainless valves and 84# dual springs ready to be installed with Brian Crower Stage 2 cams.
Getting closer to completion.
jpg  IMG_20161231_190456.jpg (107.71 KB)
39_586871fe6aaec.jpg 700X1244 px
Posted on: 2017/1/1 3:02
'73 2 Door Sedan
16 valves, twin cams
awesome
Posted on: 2017/1/1 3:46
