« 1 ... 75 76 77 (78) 79 80 81 ... 97 »
Re: Super Bee KA24DR Mod
From Snohomish, WA USA
Thanks Dave.
Block is done as well. Waiting for my piston rings to come back from Total Seal. Also waiting for new timing chain. Couple mods to the car in the meantime. Need to install a Purge valve for my Nitrous. Never had one and never wanted one. Always thought they were there just to make you look cool but they do serve a purpose.
Need to pressure wash the engine compartment and re-spray fresh paint.
For now other projects are getting done around the house.
jpg  IMG_20170101_120910.jpg (46.07 KB)
39_586962170706c.jpg 700X393 px
Posted on: 2017/1/1 20:08
'73 2 Door Sedan
Crower Stage 3 Cams/SS Valves
Forge CP Pistons/ Eagle Rods
Ford 8.8/Mini Spool/4.11
Just looking at your cams from JW
are they solid billet units or other?
Ive always wondered why not just delete
the ends off after the lobe as there
is no support just extra weight for
running crankfire ecu igntion
jpg  ka24de head.jpg (90.29 KB)
737_5869b46572a3a.jpg 758X374 px
Posted on: 2017/1/2 2:01
I see that but not going to mess with it. My luck something would go wrong.
Posted on: 2017/1/2 18:57
'73 2 Door Sedan
Block and head is done. Picked them up today. Block was clean and not a speck of paint.
Total Seal Piston Rings came in so I had the machine shop open the gaps on the rings. Standard was around .016". They are now gapped to .026". That was per Total Seal recommendation because of running nitrous and boost.
Posted a picture of the top ring with the groove for the second top inner ring. Oppose the gaps and you get a Gapless ring.
May start putting it back together tonight.
jpg  IMG_20170106_150747.jpg (87.09 KB)
39_58702675636a2.jpg 535X350 px
jpg  IMG_20170106_150015.jpg (45.64 KB)
39_5870268a634b1.jpg 700X393 px
jpg  IMG_20170106_150518.jpg (179.23 KB)
39_5870269c14560.jpg 1305X1021 px
Posted on: 2017/1/6 23:22
'73 2 Door Sedan
Cranks installed with rear main seal. Went with King Racing Bearings instead if the standard King Bearings. A lot more expensive but it was worth it. I'll install the Pistons tomorrow and maybe the head. No rush but racing does start in March.
Looking forward to a fresh motor.
jpg  IMG_20170106_212836.jpg (43.30 KB)
39_58707ce246d1d.jpg 700X393 px
jpg  IMG_20170106_212757.jpg (53.07 KB)
39_58707cf6467ec.jpg 700X393 px
jpg  IMG_20170106_212255.jpg (35.38 KB)
39_58707d0234cb9.jpg 700X393 px
Posted on: 2017/1/7 5:35
'73 2 Door Sedan
100 horsepower done. 300 to go.
jpg  IMG_20170108_234520.jpg (50.91 KB)
39_5873403033882.jpg 700X393 px
jpg  IMG_20170108_234446.jpg (45.30 KB)
39_5873403ddaa9d.jpg 700X393 px
Posted on: 2017/1/9 7:48
'73 2 Door Sedan
massive rods
Posted on: 2017/1/9 8:31
longer than long john silver!
Posted on: 2017/1/9 10:42
Tomorrow I'll finish putting it together.
Been at work the last two day.
Always looking forward to another finish project.
Posted on: 2017/1/11 6:09
'73 2 Door Sedan
After damaging an oil ring and waiting for a new one to show up and other stuff going on in life, I finished up putting the motor back together.
D, that photo you posted of that head with the missing last cam caps, my head has those caps. Not sure what head came off of.
Going to put it back in the car in the next few days.
jpg  IMG_20170128_213501.jpg (48.44 KB)
39_588d8212594bf.jpg 700X393 px
jpg  IMG_20170128_213638.jpg (78.51 KB)
39_588d822100ab2.jpg 700X545 px
Posted on: 2017/1/29 5:58
'73 2 Door Sedan
