(1) 2 3 »
A15 cam bearings
From Fort Worth, Texas
DD....as much as I wanted to Not replace cam bearings for my rebuild, after a close inspection I don't have a choice. One of the cam bearings has significant damage. However the camshaft journal does not show this kind of damage. Doubt the machine shop would of done this. They only honed the cylinders, decked the block and used a mild cleaning solution. Any idea how this could of happened? Also was not able to find the cam bearing part number in Tech Wiki.
jpg  A15.cam.bearing.jpg (114.38 KB)
20677_5899de090d078.jpg 960X720 px
jpg  A15.cam.bearing1.jpg (96.97 KB)
20677_5899de4c194b7.jpg 720X960 px
jpg  A15.cam.bearing2.jpg (121.66 KB)
20677_5899de793eb0a.jpg 960X720 px
jpg  A15.cam.bearing3.jpg (93.10 KB)
20677_5899de9b9068a.jpg 960X720 px
jpg  A15.cam.bearing4.jpg (129.44 KB)
20677_5899deb9b8fc9.jpg 960X720 px
jpg  A15.cam.bearing5.jpg (141.33 KB)
20677_5899ded44adbc.jpg 960X720 px
Posted on: 2017/2/7 14:53
Re: A15 cam bearings
From Hawaii, USA
Rockauto
* ITM ENGINE COMPONENTS 5C4146STD
* SEALED POWER 1592M Camshaft Bearing Set
Posted on: 2017/2/7 20:25
Ok thanks. Isky did a regrind for a mild performance cam. Journals should be the same diameter so I can stay with standard size bearings?
Posted on: 2017/2/7 20:43
From Hawaii, USA
As long as the cam you sent them to regrind is STD size, yes
Posted on: 2017/2/7 21:07
From Hawaii, USA
Yes, that is when you want to replace the cam bearings (when they are damaged). It's no big deal, just put the new bearings in and have a machine shop line-hone them
Posted on: 2017/2/8 0:56
Yea this is a set back for me. Machine shop that I use here locally is highly recommended but super slow. I told him not to do anything with the cam bearings so he never did take a look. It must of been debris. Interesting though that the cam journal has no damage. It is the second bearing from the rear of the engine. One bit of good news though is that my crankshaft end play is within tolerance, .003. Well I'll be ordering bearings and dropping off the block and camshaft next week sometime. Thanks for the information.
jpg  Isky.cam.jpg (109.68 KB)
20677_589a9e374f4f5.jpg 960X720 px
Posted on: 2017/2/8 4:28
Quite a regular
Almost looks like it is from a poorly reground cam, couple of front lobes base circle not ground to the correct size to clear the journal.
Posted on: 2017/2/8 21:40
So your indicating that the front lobes not ground properly put stress on the camshaft towards the rear which is where the damaged cam bearing is? Why wouldn't the cam journal be damaged as well? If the cam has been reworked, I hope the journals were not turned. I ordered a standard size set of bearings and should be here early next week. Will have my machine shop make sure I have the right size. Any idea what the bearing/journal tolerance should be?
Posted on: 2017/2/9 14:40
From Hawaii, USA
Not off the top of my head. You'll find the tolerance in a Datsun/Chilton/Clymer repair manual -- or at least journal diameter and bearing thickness. The proper clearance is achieved by line honing. Boring is not needed due to the tight manufacturing tolerance of Nissan, just the finish aligning hone. Some guys have skipped this step, if you fit the cam and it's easily turning and otherwise is in spec
* Cam bend limit
* Cam journal diameters
* Cam bearing diameter/thickness
* Cam thrust plate clearance
Posted on: 2017/2/9 19:06
From Adelaide
The damage looks like it was most likely cause during assembly or dis-assembly. i.e. the scores are in the direction the cam moves when it's removed or installed. It's possible they have been there all along, keep in mind a white metal bearing is there to "absorb" hard particles. The majority of the time the cam is spinning on a film of oil and not touching the bearing at all.
I think what Volodkovich is getting at is if the base circle of the lobe was too big it might have scored the bearing on the way in or out. Could be a number of things, debris during assembly, rough handling. If in doubt, measure everything and sit and think about what it's all supposed to do.
Posted on: 2017/2/9 19:55
1200 Coupe A15E - ITB
Lamb Daiquiri - a man's cocktail!
(1) 2 3 »
