Browsing this Thread:   3 Anonymous Users
Brakes, 2nd time around.
From Sunnybank, Brisbane
I'm on the opposite side of the country to my ute at the moment and my legend of an old man is working on some things for me. I'm looking to upgrade the front discs from stanza to something ventilated, newer and generally better.
Would someone be able to give me the measurements of the standard size stanza disc please?
I know PCD is 114.3, caliper spacing is 88.9mm but i'd like the centre bore diameter, hat diameter and the hat offset (i think that's what it's called)
I'm not trying to reinvent the wheel, but i thought there may be more disc options available other than the 20 year old stuff on the wiki brake upgrade section. In any case, wish me luck.
Thanks
Jimbo
Posted on: 2017/3/15 11:36
Re: Brakes, 2nd time around.
A10 Stanza/510 brake rotor:
Nissan 40206-U6700
DBA 307
* Height: 35.5 mm
* Thickness: 10 mm
* Hub reg: 73 mm
* Bolt pattern: 4 x 95 PCD (bolts to hub)
[edit: fix photobucket link]
Posted on: 2017/3/16 5:54
Edited by ddgonzal on 2017/9/3 22:55:00
Absolute LEGEND!
Cheers
Jimbo
Posted on: 2017/3/16 6:01
20 years old? Nothing that new in the wiki
For Stanza struts, these are the newest(?) the wiki talks about :
* Falcon XF 287mm ventilated rotors
* Verada 276mm ventilated rotors
Brake Swaps
Posted on: 2017/3/16 6:04
Slow progress on this little project. (I'm in Perth and car is in Brisbane )
I'd appreciate input on the option that I'm considering at the moment. I couldn't find a disc that would be a direct bolt-on for the stanza strut that would fit under 14's so i've come to a new solution that may be just as good. A mazda BT-50 2wd has disc's that are 255.5mm diameter and does not have a "hat" I.E. they're are only as high as the thickness of the disc (24mm). So i'm thinking of using them and fabricating a custom rotor hat to attach behind the hub, same as the standard solid disc. Is this the right way to go, or am I reinventing the wheel for no reason?
Caliper options are the factory BT-50 single pistons, but for pad options i'm leaning towards the late model Subaru stuff that also suit 24mm but twin piston.
The aim is to get vented discs, no track increase, fit under 14's and have parts availability in years to come... without breaking the bank of course.
As always, thanks for any feedback
Jimbo
Posted on: 2017/8/31 12:43
From gold coast QLD australia
Iknow the Hyundi sonata front rotors slip straight over the datsun stud pattern and early commodore calipers bolt on
Posted on: 2017/8/31 23:14
GO RACING,GO HARD OR GO HOME!!
SLY OLD FOX..................
From Albury
What about the S13 upgrade . Easy and works great
Posted on: 2017/9/1 7:21
I thought the s13 stuff only suit the 1200 struts, I'm running stanza with coilovers. Am I right or am I wrong? I'm trying to avoid the extra track increase of putting rotor over hub as my wheels are close enough to the guards now. I know it's not much, but the extra few mm of rotor would push it a little too far I think.
Posted on: 2017/9/2 10:09
tech article: Better Brakes for A10
* 268mm brakes from 280ZX are the go for 14" wheels, but those are non-vented and increase track
* Maddat kit FBK001 has 280mm vented discs and RX7 calipers. Does not affect track
Posted on: 2017/9/3 23:01
Trying to go vented, under 14's. So the 280mm vented jobs won't fit.
If i use this (see image) BT50 rotor with no modifications and use a custom rotor hat I can fit it behind the hub. I don't like the idea of machining rotors, too much stuffing around when i need new ones again.
jpg  bt-50 rotor.jpg (58.80 KB)
4451_59acd0cee0ead.jpg 935X566 px
Posted on: 2017/9/4 5:06
