(1) 2 3 »
Datsun 1200 Brake Hard Lines
From Lisbon
Hi!
Datsun 1200 Year 1973 brake lines is M10*1?
Please let me know, because i want buy new flexile hooses and adapters to BMC underdash.
Many thanks on advance
Luis
jpg  Thread 1.jpg (23.13 KB)
6267_5901bb34035ef.jpg 638X638 px
jpg  Join Box.jpg (20.67 KB)
6267_5901bb4737f27.jpg 441X588 px
Posted on: 2017/4/27 10:35
Re: Datsun 1200 Brake Hard Lines
Yes, M10 metric fittings
Posted on: 2017/4/27 13:15
From Lisbon
Hi!
Thanks, please let me knoe the meaning of
4 Steel Brake Adapter Fittings M10 x 1.0 (Metric 10mm) to 3AN -3
http://www.ebay.com/itm/4-Steel-Brake ... t%3D6%26sd%3D232025193713
I dont what is means
3AN to -3 AN3
Thanks
Luis
Posted on: 2017/4/27 16:15
http://autobilda.com/Reusable%20Aluminum%20Fittings
The steel hydraulic lines used to replace rubber hoses have their own unique code of thread sizes. The above link should give you more detail and how the sizes are called eg -03an (called dash 3 when you are talking about sizes).
So those fittings enable you to adapt steel hoses to metric threads.
Posted on: 2017/4/27 23:34
Yes, AN threads are not used by factory automobiles -- they are an aerospace standard -- originally Army/Navy (AN). Often used by race cars and hot rods
Posted on: 2017/4/28 5:14
From Lisbon
Hi!
Many thanks for your quicly replies.
I want some brake adapters. is dificult find 3/8 24 to m10*1 inverted flare and a 90º one
As i said i have dual brake master cilinders underdash, and i must have one 90ºangle 3/8 24 outside bmc and a 40inch hoses to juntion box on firewall wit adapter from 3/8 24 to M10*1.
My question is: Is a problem have a 40" hose to long from bmc to junction box?
Please let me know where i can find this adpaters?
I just want ride my car..... iT ALMOST A YEAR IS PARKED.....
Luis
Posted on: 2017/4/28 15:31
You may have to use a 2 part 90deg connector. Have a look at #220-10416.
http://www.wilwood.com/LineKits/LineKits2.aspx
Posted on: 2017/4/29 0:10
Why flexible hoses being used? Surely could make some hard lines from under dash unit and bend to suit. 40inch is a lot of hose
Posted on: 2017/4/29 3:26
Yes, 40" is too long, too much hydraulic flex. A steel braided hose can be used, but will be expensive and big. A small hard line works better, fits better and costs less. Use an inexpensive tubing bender to shape it
M10 to 3/8" adapters can be found in any local auto parts store here ... adapters
Posted on: 2017/4/29 4:47
From Lisbon
Thanks, i will do it
Datsun 1200 Hard lines are 3/16"?
Please check this item, and let me know if it fits. Its in cooper not a problem? Its soft?
In afirmative way i will buy it
Thanks
Luis
Posted on: 2017/4/29 18:33
Edited by Luigi on 2017/4/29 18:50:34
Edited by Luigi on 2017/4/29 18:51:48
(1) 2 3 »
