« 1 ... 82 83 84 (85) 86 87 88 ... 96 »
Re: Super Bee KA24DR Sedan
From Snohomish, WA USA
I'll shoot a photo of the damper tomorrow along with the new pulley. I should be getting it back up n the morning.
Posted on: 2017/5/16 19:42
'73 2 Door Sedan
Crower Stage 3 Cams/SS Valves
Forge CP Pistons/ Eagle Rods
Eaton M62 SC 10 lbs. Boost / 150hp Progressive Nitrous
Ford 8.8 Posi/4.11
Supercharger pulley on the left and damper in the middle. Stacked and then installed. Gone for a couple of days so I'll drive it on Saturday.
jpg  IMG_20170517_201554.jpg (58.07 KB)
39_591d1363ea925.jpg 750X421 px
jpg  IMG_20170517_201644.jpg (58.45 KB)
39_591d1378b6ba4.jpg 750X421 px
jpg  IMG_20170517_202026.jpg (138.84 KB)
39_591d14048b8e1.jpg 750X1333 px
Posted on: 2017/5/18 4:26
'73 2 Door Sedan
Ford 8.8 Posi/4.11
This is my plug after 15 lbs of boost and 185hp shot of nitrous.
Hard to see but my burn is past the 90° bend in my ground electrode so a bit to much timing. 32° advanced with a 10° retard chip when on nitrous. Going to up it to 12°. Also a little lean on the fuel so will up the the nitrous fuel jet two sizes. See what those changes will do. Racing June 2 and then June 10,11.
jpg  IMG_20170520_111251.jpg (54.98 KB)
39_5920873cb9b47.jpg 750X421 px
Posted on: 2017/5/20 18:51
Edited by datsa73 on 2017/5/20 19:13:20
'73 2 Door Sedan
Ford 8.8 Posi/4.11
Another 1/8 mile run. Car pulls pretty hard.
Dan's running a big block Chevy in that Camaro with 100 shot of Nitrous. I think Im doing very well against the big boys.
1/8 mile drag
Need to get to the 1/4 mile track soon.
Posted on: 2017/6/17 6:42
'73 2 Door Sedan
Ford 8.8 Posi/4.11
Nice work. Since it is supercharged, why not go down to 30 degrees advance and stay at -10 on nitrous?
Posted on: 2017/6/17 9:42
Right now I am at 32° advanced. When on nitrous my MSD box retards 12° so that puts me at 20° advanced. That's my sweet spot.
Updated picture of engine compartment.
jpg  IMG_20170617_093908.jpg (64.89 KB)
39_594562da90014.jpg 750X421 px
Posted on: 2017/6/17 15:26
Edited by datsa73 on 2017/6/17 18:10:03
Edited by datsa73 on 2017/6/17 18:12:00
'73 2 Door Sedan
Ford 8.8 Posi/4.11
Enjoyed an evening at Renegade Raceways in Yakima WA.
4 Passes with consistent times of 11.6 sec. at 116 mph. The 5th pass I ran a 12.84 because my Nitrous bottle emptied on me 3/4's of the way down the track.
Car is running stronger than ever but I was expecting better times with the engine rebuild.
Dial In with a close win at the end.
Renegade Raceway 1/4 mile VIDEO
Posted on: 2017/6/24 20:13
'73 2 Door Sedan
Ford 8.8 Posi/4.11
Looks like the car is liking the 200hp shot of nitrous. Ran a fraction....fraction of a second faster than the 11.50 cutoff for equipment requirements. 11.491
Went back to Tech. Need a 5 point cage and fire jacket so they made me slow it down.
Tomorrow the car is going into the shop for a Chrome-moly 6 point cage.
Hopefully it won't weigh much more than my steel 4 point.
jpg  IMG_20170715_141231.jpg (62.91 KB)
39_596a86396d934.jpg 750X1333 px
Posted on: 2017/7/15 22:23
Edited by datsa73 on 2017/7/16 3:36:57
'73 2 Door Sedan
Ford 8.8 Posi/4.11
Was at Import Face last month at Pacific Raceways in Kent, WA.
Ran consistent times and the fastest at 11.31 @ 118 mph.
Oh yeah, had the new cage put in so no more hassle from Tech.
Ended up running the motor a bit lean and lost compression in the #3 cylinder. Toasted the piston.
So a new full set of pistons and went to a new engine block.
Should have it back together this week with one race left on the season.
Bought a second stock motor and will build that one over the winter.
It's all a learning curve.
jpg  FB_IMG_1504106874237.jpg (99.86 KB)
39_59c5536e7a7a4.jpg 1080X565 px
Posted on: 2017/9/22 19:21
'73 2 Door Sedan
Ford 8.8 Posi/4.11
What a warrior you r mate, you never give up making your killer wasp meaner!
Before leaving Oz saw a vw bug with 2.5 stroker that did 10s with a holley turbo.
Which I wanted to question would a blowthrough carbed turbo be better for the KAs
capacity, long stroke and torque as its more suitable for lower revs?
Posted on: 2017/9/24 3:51
