« 1 2 3 (4)
Re: Wear Rocker arm
Iskenderian sells springs for the Nissan A engine
Posted on: 2017/9/20 4:54
Re: Wear Rocker arm
From Lisbon
My camshaft has wear too. i need regring again another one...................
i HAVE an A15 h50
This time I must buy a elecrical fuel pump, i saw 17010-A7600 17010-A7601 and this model is for Carburetor vehicles requiring a low pressure pump and to replace factory electric or mechanical pumps
1.3L/min @ 29kPa/4.2psi
Mikuni recommended fuel pressure is 2.84 - 4.98 psi
I think its not need a regulator, please let me know
and i will order the springs from Iskenderian to avoid any doubts
Im counting with your advices
Thanks
Luis
Posted on: 2017/9/20 19:40
Edited by Luigi on 2017/9/20 20:28:29
Edited by Luigi on 2017/9/20 20:29:31
Edited by Luigi on 2017/9/20 20:34:24
Edited by Luigi on 2017/9/20 20:40:25
Edited by Luigi on 2017/9/21 8:59:06
Re: Wear Rocker arm
From Lisbon
What kind of lifters do you use with a longer cam duration?
The first time i used Nissan Part Number: 13231-78201 720 Pickup 4 Cyl 2.2L Diesel, 4 Cyl 2.5L Diesel
SD22, SD25, but the first lifter by side of distribuition must be shave because touch slightly the camshaft.
What do you recomend used standard ones? or 13231-78201 have larger head on them, prevents uneven wear on camshaft lobs.
Posted on: 2017/9/21 17:20
Re: Wear Rocker arm
From Las Vegas USA
I use the standard lifters; current cam in the A15 is 278 Duration with .420 lift. I try and keep that motor to 7800 rpms but it does see 8200 on occasion.
The cam in the A12 was 286 duration with .460 lift and I used standard lifters with that as well. I was revving the A12 to 8600 rpms on a regular basis, the rings wore out after two seasons and when I pulled the motor apart the lifters looked fine.
With all that said keep in mind that as a track only car I'm doing all of 900 miles a year; granted it's 900 miles with the motor above 5000 rpms most of the time.
On the electric fuel pump I use one of those square Facet brand pumps, because the carbs are Keihin Flat Slide bike carbs I use a regulator at 1.2 - 1.5 psi.
Posted on: 2017/9/22 6:07
Re: Wear Rocker arm
From Lisbon
hI!
i taken measures on camshaft with more precision, and the cams are ok, but some have some shadows and one have a litle material dent.
Please give me your opinion? Its a big deal? or take the risk and assembly it with this material dent on cam? The lifter will make some pressure in all cam and will toutch the dent too, im afraid the lifter will increase the cam dent?
Thanks
Luis
jpg  IMG_0395.JPG (77.80 KB)
6267_59c8ccf83c4cf.jpg 640X480 px
Posted on: 2017/9/24 23:18
Edited by Luigi on 2017/9/25 10:19:57
Edited by Luigi on 2017/9/25 10:24:28
Edited by Luigi on 2017/9/25 10:31:05
Edited by Luigi on 2017/9/25 10:31:16
Edited by Luigi on 2017/9/25 10:31:38
Re: Wear Rocker arm
From Lisbon
hI!
Can i use new standard lifters on my actual cam with 20 houres of use?
I set up on my A12 block with a12 pushrods a A14 Gfu cylinder head, can i use the A12 pushroads?
Thanks
Luis
Posted on: 2018/5/23 15:34
Re: Wear Rocker arm
Yes, also use cam assembly lube and proper cam break-in procedure
Yes, you must use A12 pushrods with A12 block. The A14 pushrods are about 15mm longer and so will not fit (A14 block is 15mm taller than A12 block)
Posted on: 2018/5/23 23:37
« 1 2 3 (4)
