Hydraulic Clutch Master Cylinder Shim
From Cambria, California
What purpose do the (2) half shims between the clutch master cylinder and the firewall serve? No reference in the Tech Wiki or Ye Olde Shoppe Manual. Inquiring minds want to know...thanks!
Posted on: 2017/10/30 22:22
Re: Hydraulic Clutch Master Cylinder Shim
From Mordialloc Victoria 3195
I would say its so the m/cyl piston comes all the way back to allow fluid back into the bore - if it doesnt your brakes eventually lockup - dont ask me how I know :)
dp
Posted on: 2017/10/31 1:45
keep it simple
Factory Service Manual discusses this. RHD shoppe manuals do not
Yes, they are adjustment shims, so the fluid doesn't back up. Unlike B210, B110 doesn't have an adjustable pushrod, so the master cylinder is moved via the shims. See Hydraulic Clucth Adjustment in our tech wiki
Pedal stroke is 5.65 in (143.5 mm) with the adjustment stop (the switch in the diagram) backed off. Adjustment is made with shims for the cylinder on the firewall.
FSM diagram
Adusting Shim
* 30611-27260 1.6 mm
* 30612-27260 0.8 mm
* 30613-27260 0.5 mm
Posted on: 2017/10/31 3:58
Thanks, gentlemen. I suppose I should rummage through my Ziplock bag of shims and install an appropriate set then, eh?
Posted on: 2017/11/4 6:36
