Stock air cleaner on 32/36 weber done right
I like the stock air cleaner, so when I installed a 32/36 weber I wanted to modify it to suit. It's been done a few times before, but I took my own approach. It was not particularly easy or cheap but I'm very pleased with the outcome.
Basically I bought a Redline universal air cleaner adapter to 5 1/8" and welded 17mm of 5" gal steel pipe to the bottom of the air cleaner.
jpg  99010457.jpg (97.70 KB)
7711_5a1927114d353.jpg 800X640 px
Posted on: 2017/11/25 8:17
Edited by SunnyDaze on 2017/11/29 4:23:44
Re: Stock air cleaner on 32/36 weber done right
The pipe, about 128mm ID, nominally 5 inch, is a perfect fit.
Posted on: 2017/11/25 8:19
A friend who has a machine shop helped me cut the air cleaner. Not necessary, but helped a lot and produced a clean outcome.
Posted on: 2017/11/25 8:28
Tacked on the pipe with an arc welder. Not bad for a rough job, lots of holes but solid as. Afterward I cleaned up the weld and filled it with Devcon titanium putty. Good stuff.
Posted on: 2017/11/25 8:37
Touched up with VHT Pontiac blue engine enamel, which should really be called Datsun air cleaner blue enamel in this market.
Posted on: 2017/11/25 8:46
Posted on: 2017/11/25 11:17
Edited by unfamilia on 2020/3/29 13:04:15
From Mordialloc Victoria 3195
COOL
Posted on: 2017/11/26 4:20
keep it simple
The bonnet has plenty of clearance, but it is a 120y. I was able to reuse the main support stay so it is not that much higher than stock. I could not reuse the small stay - tiny bit too tall, but it interfered with the fuel line. With such a wide base it seems very solid anyway. It all just fits with 17mm of 5" pipe. Might have been able to get it a couple of mm lower but it needed to clear the fuel inlet on the carb, and be sufficiently tall to cover the cut-out on the breather pipe port.
Posted on: 2017/11/27 9:52
From Biloela, Sunshine State
Stealthy as mate. I might use this idea if you don't mind.
Looks good!
Posted on: 2017/11/28 2:52
Didnt know Redline had such an adaptor but also
many people dont know Rowland manifolds have the
cheapest around 180a udto your door manifolds that
take the weber 32/36 38/38 28/36 etc listed below
http://www.manifolds.co.za/index.php? ... =item&item_id=50&Itemid=2
gives better flow than that vanette one
Posted on: 2017/11/29 14:55
Edited by D on 2017/11/29 15:13:25
