FS: Datsun 1200 Coupe CA18DET Race Prepped [Sold]
From SE Melbourne
1970 White Datsun 1200 Coupe
Body is in great (very straight) condition with no rust!
CAMs approved roll cage fitted by Fabraications - all painted up
Comes with front grill and rear valance (just not fitted)
"Boofhead" strut brace - very nice.
CA18DET complete
Custom winged sump (higher capacity and baffled for racing)
"ca18det_man" custom cross member, lower and closer to firewall than Maddat
New ARP bolts up to flywheel
Side pipe exhaust
Custom oil catch can
Radiator overflow can
Full CA18DET wiring loom and 2 stock CA18DET Engine ECUs (not fitted)
New Gates timing belt fitted
New Bosch fan belt
Turbo piping done including blow off valve
S13 radiator with thermofan
Front mount intercooler
Stumpy 5 speed gearbox fitted with custom cross member
H165 diff
Sumitomo twin piston front brakes, H165 ute rear drums
Carter black lift pump
Bosch 044 Motorsport EFI pump
EFI hardware surge tank
All new custom 5/16" bundy tube fuel lines
Extras
Fullriver HC20 AGM sealed battery mounted in rear floor
Cool bobtail spoiler (Steve Draehim design)
Additional original sump
Lots of spares, piping, air flow meters, extra coil ignitors, etc....
Datsun heater core if you want to get it back on the road
Main jobs left to get it up and running.
Getting the engine loom and, the fuel pumps connected to relays and wire in an ignition switch
Fit a pod filter on and connect up piping from intercooler to throttlebody
Get a tailshaft to connect from the stumpy 5 speed to the h165 diff
Put some nicer wheels on it
(Then just all the other little jobs that have been forgotten)
It has been stored under cover and kept dry for at least the last 12 years, the previous owner Bruce also always had it stored undercover, probably why the body looks so nice.
Reason for selling - I've moved from a house with a double garage all for me, to pretty much no garage at all....love to see if go to someone who wants to set some laptimes. Hillclimb or circuit I think it is going to be awesome.
Posted on: 2018/6/17 3:53
Edited by Mildman on 2018/6/17 8:46:16
Edited by Mildman on 2018/6/17 8:47:01
Edited by Mildman on 2018/6/23 0:28:09
Mildman, Datsunless
Re: FS: Datsun 1200 Coupe CA18DET Race Prepped [Sold]
Wow, I was going to say to hang onto it Ben and build some sort of carport for it (I'm guessing your in a rental, so building a garage was out of the question)... But you've sold it already!
You were about the only one with an unfinished project running for as long as mine. Shame you never got the joy of driving it in anger. Although no doubt it would still fall short of many of the modern vehicles you've been track testing over the last few years.
Hopefully the new owner will setup a project build thread on here so we can see it to completion.
Posted on: 2018/6/17 11:00
From Melbourne, Australia
Bugger. Wrong way for your project to end old mate
Posted on: 2018/6/17 12:04
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
great price regardless unfinished or not, someone got a bargain
Posted on: 2018/6/17 12:47
From SE Melbourne
Thanks guys, it is a shame, just no way to keep working on it where I currently live.
It's heading to a good place at least, I'll reveal the new owner if they are cool with it soon.
Posted on: 2018/6/17 13:03
Mildman, Datsunless
From MOOROODUC. Victoria
So you retrieved it from Hastings?
Posted on: 2018/6/17 21:31
