« 1 (2) 3 »
Re: 79 210 B310 fusible link
From South Dakota USA/Trinidad and Tobago
Ok I got the choke sorted and it starts up n idles no problem. But it’s still misfiring. While it was idling I tried pulling off the plug wires and it died when I pulled the number 1 and 4 wires. Also where we start it up from cold it idles super high.,,like at about 2000rpm(no tach so just a guess). I’m trying to get a compression tester so I can check it. Could it be the carburetor causing that or maybe the egr? I’m stumped
Posted on: 2018/10/15 1:00
3NE 2NR
2000 rpm is within spec for fast idle, so no worries
carburetor won't cause 1 or 2 cylinders to not fire. EGR won't do that either. It's usually a much simpler cause
so if you pull off #2 wire it doesn't die? And same for #3 wire? Maybe they are swapped
Posted on: 2018/10/15 1:47
Thats what I'm thinking because the carb seems to be ok. I already changed out all the basic ignition parts for new ones so it should be running smooth. I will check those again tomorrow. Here’s a video link below of the car running today
https://youtu.be/3ABrctm0VBQ
I just hope it's not a blown headgasket
Posted on: 2018/10/15 2:14
Edited by sunny1046 on 2018/10/15 3:22:38
Edited by sunny1046 on 2018/10/15 5:32:12
3NE 2NR
Turns out the plug wires were in the right order and the car is still misfiring. Im thinking maybe the head gasket is torn between #2 and #3 cylinders.Its crazy that it fires up and idles so good. I know its not that hard to change the head gasket but my car is a Cali spec and has all that smog crap on it. Its a little intimidating.
Posted on: 2018/10/16 2:52
3NE 2NR
If it idles perfect it's unlikely to be the head gasket. But give it a compression check. On several 210 I workd on the coil was going bad, idled good but missed when revved
By the way, every 1979 USA car has the smog stuff, ford chevy whatever. They didn't run very well compared to Datsuns
Posted on: 2018/10/16 8:04
From sydney australia
I've replaced the fusible link in my B310's with a fusible link from the N12 Pulsar, which was easy when they were in every wrecking yard. This also gave an extra battery outlet for accessories. I think they sold this car in the US as a 310. Sounds like you fixed this problem already. As for the misfire, check the coil, as it could be breaking down. If it doesn't cure the problem, at least you've got a new coil.
Posted on: 2018/10/16 10:19
I bought a compression tester this morning so later after work I’ll check it. I also ordered a new coil that isn’t here yet. Haven’t gotten around to messing with the fusible link since I’ve been trying to get the car running properly. But I did buy the Bussmann fmx fuse thing.
@ddgonzal how to i go about wiring up the fmx fuse to the car? I’m a total novice when it comes to electrical stuff
Posted on: 2018/10/16 18:20
3NE 2NR
1. Cut the melted fusible link from the wiring harness
2. Crimp male blade terminals to the harness
3. Plug in the FMX
Male blade terminals are available at Oreilly's, NAPA, AutoZone, Wal-mart, etc
jpg  male blade terminal.jpg (23.68 KB)
174_5bc681315016f.jpg 256X224 px
Posted on: 2018/10/17 1:23
Your 210 must be an early 1980 model? What month does it say on the door jamb build plate?
NISSAN 24022-W5000 FUSIBLE-LINK WIRE 1980-1982
* one red, one green
This photo looks like there are two green wires + the red wire
in which case you'd need three FMX fuses
Posted on: 2018/10/17 1:28
Awesome thanks man! My car is a 1979 and yes it does have 2 green and one red wire. The melted connector has the 2 green wires connected to it. The other connector has the green wires and the red wire which is looped. So I'll have to use the fmx for just the green wires then?
Posted on: 2018/10/17 4:54
Edited by sunny1046 on 2018/10/17 5:15:13
3NE 2NR
« 1 (2) 3 »
