Racers what starter are you using.
From Las Vegas USA
So out of curiosity for my fellow racers which / what starter are you using.
I've managed to put another A15 together for my car and this one has 12-1 compression. On initial start up it didn't crank through as easily as the 11.9-1 motor did. I'm expecting the motor free up a bit. Note I'm using a non gear reduction type starter.
Posted on: 2018/11/27 5:36
Re: Racers what starter are you using.
From Cambria, California
Tom - on my 13-1 A12 I'm using a rebuilt Bosch starter. (non-gear reduction) It cranks just fine. My fabricator added a #2 ground wire from the engine block to a bare metal ground point on the chassis to ensure a decent grounding circuit, which is quite important for a starter ground.
Posted on: 2018/11/28 3:09
From Las Vegas USA
Stan I cranked it up for a split second last night and it seems fine. I think my issue is simply one of I was used to cranking up the 5 season motor which one would expect to crank a bit easier.
My block ground is attached to bare metal as well.
Posted on: 2018/11/28 4:29
The best starter I ever used on A-series was a Bosch starter. It cranked well and lasted longer. Original 1200 starters were junk, though later A14 starters were OK
Stock Datsun 1200 uses a chassis-to-block ground wire, but these have sometimes been removed over the years
Posted on: 2018/11/28 4:39
[Stan said]: I'm using a rebuilt Bosch starter. (non-gear reduction) It cranks just fine
Bosch SR136X on special sale -- $33 at RockAutocom
Looks like a later Hitachi from a Datsun B310. These are the reliable 4-brush design and are 1.0KW instead of the original A12 0.9KW
jpg  SR136Xback.jpg (128.19 KB)
174_5d2e400fb6059.jpg 1500X932 px
jpg  SR136Xfront.jpg (93.69 KB)
174_5d2e401f7ad67.jpg 1500X712 px
jpg  SR136Xleft.jpg (179.07 KB)
174_5d2e402b3e159.jpg 1500X1459 px
jpg  SR136Xright.jpg (163.13 KB)
174_5d2e4034ba873.jpg 1500X1469 px
Posted on: 2019/7/16 22:23
At Walmart.com -- IMI Performance starter (Bosch OS Gear Reduction), small diameter, high torque only weighs 4.14kg 1.2kw
$229
looka like Honda starter with an adapter plate
jpg  IMI-255-001B1.jpg (17.36 KB)
174_5d2e658e7abfc.jpg 450X450 px
jpg  IMI-255-001B1_.jpg (17.21 KB)
174_5d2e66acd348b.jpg 450X450 px
Posted on: 2019/7/17 1:10
