Wanted - 1 x used standard A15 piston (sample for forging supplier)
From Mordialloc Victoria 3195
Because getting forged pistons here in Aus ars sooo expensive,
I wanting 1 x used A15 piston if anyone in Melbourne has one lying around (I threw my used ones out)
Its to send over to the USA as a sample so they can make a set ( or more if anyone
else wants some made up ).
This is for my clubman7 Turbo 2.0 project so the standard 8.9:1 compression pistons will be just fine
Cheers dp
Posted on: 2019/1/8 20:16
keep it simple
Re: Wanted - 1 x used standard A15 piston (sample for forging supplier)
From Adelaide
I probably have one in the shed but I'm in Adelaide these days. Are you going for flat tops or just getting forged versions of the stock pistons?
I'm sure someone closer by has one. This might be a bit far out but maybe one of our friends across the pond could post one to the shop for you?
Posted on: 2019/1/10 9:40
1200 Coupe A15E - ITB
Lamb Daiquiri - a man's cocktail!
From Perth
Keen to see pricing on such things
Posted on: 2019/1/10 11:45
tried pjz yet?
Posted on: 2019/1/10 14:43
In USA we got three different A15 pistons, and none were 8.9:1. So you'd probably best get the local ones
* centered dish, shallow
* centered dish, deep
* offset dish (different dish than JDM type)
Posted on: 2019/1/11 6:42
DD: What was the compression on the US spec shallow centre dish ?
dp
Posted on: 2019/1/15 6:18
keep it simple
Forged version of stock - This is for Turbo 2.0 so standard comp ( around 9:1 )
Posted on: 2019/1/15 6:23
keep it simple
First Quote is about AU$1000/set if I buy 3 sets
Anyone in the US bought forgies that I could contact or is US$650 - 700/set what you pay over there?
Our crappy AU dollar at the moment dosen't help
Posted on: 2019/1/15 6:29
keep it simple
USA A15 compression was 8.3 to 8.5 due to larger dish
Every automaker has gone to high compression with turbo. Only in racing classes do they still use low compression with turbo
PAECO forged
http://www.paeco.com/Piston%20Prices.htm - L16 $460 set
http://www.paeco.com/Piston%20Ordering.htm - Pistons can be made up for any engine in any bore size or compression ratio
Venolia piston for stock A15 is part number 10400
http://www.venolia.com - use the custom order form
forgies $80 each in 2014 - email for current price
Ross Racing Pistons
https://www.rosspistons.com/custom-pistons - use custom form for A15 pistons
for example forged set for SR20DET (4 pistons, pins & rings) $610 USD complete set
RB pistons $820 set of six
Oh, and many of these USA companies have the A15 specs on file ...
Posted on: 2019/1/15 7:15
suzuki vitara 75 cheapos will hold 25psi
You prob know Simon used PJZ pistons for
one of his builds with machined tops
Posted on: 2019/1/15 15:39
