A/C compressor on the other side?
From Sydney, NSW
Hi all just wondering if anyone has fitted an ac compressor on the alternator side of the engine block as opposed to the manifold side where the stock bracket would have gone?
This is what I mocked up and now got laser cut in heavy grade steel for the standard bracket but I was hoping to see if it's possible to move it to the other side of the block
Trying to work out how to position efi inlet and turbo and see if its possible to run ac as well.. Yes I know.I'm.asking a lot! I suspect the oil filter will get in the way
jpg  IMG_5916.jpg (119.53 KB)
12667_5c404efcd2ee8.jpg 768X1024 px
Posted on: 2019/1/17 9:46
Re: A/C compressor on the other side?
From Adelaide
Good question, it's hard to imagine fitting one in there but someone may have done it!
Posted on: 2019/1/17 10:08
1200 Coupe A15E - ITB
Lamb Daiquiri - a man's cocktail!
The original Datsun 1200 block had the alternator on the manifold side and the AC compressor on the same side. Newer blocks moved the alternator to the right side. All dealer setups had the compressor on the left side either high or low
Compressor can go on either side. See our tech article Compressor brackets. On the right side it goes above the oil pump
Here's one. Custom install on right-side, battery moved to trunk, compressor placed just above oil pump. Mounted like an alternator with no idler pulley -- it pivots to adjust the belt
jpg  RH AC compressor.jpg (42.61 KB)
174_5c405a41e149d.jpg 620X465 px
Posted on: 2019/1/17 10:36
From Sydney, NSW
Thanks yet again David wow that's cool I didn't know it might be possible to get it all in there.
Any idea who did the custom opposite side install I'd love to have a chat!
Posted on: 2019/1/17 18:44
somebody in Japan. The tech article has photos of two different ones like that, but not a lot of detail
Posted on: 2019/1/18 6:49
From Sydney, NSW
Sam suggested trying a high mount compressor on top of the alternator and try and fab up something for that on the drivers side.. Onwards and upwards
Posted on: 2019/1/18 7:06
From Sydney, NSW
Or alternatively just fabricate a turbo manifold at head port height like a higher mount turbo..
Posted on: 2019/1/18 7:40
Posted on: 2019/1/18 7:42
From Sydney, NSW
Thanks David
Posted on: 2019/1/18 7:56
here's another. You can see why the battery has to be moved
https://sun.ap.teacup.com/tabayann-b10/174.html
The compressor bracket are attached oil pump bolt and front cover. The adjuster is from thermostat housing
jpg  1245286558.jpg (72.99 KB)
174_5c427cd3b0df9.jpg 640X480 px
Posted on: 2019/1/19 1:20
