« 1 ... 5 6 7 (8)
Re: Datsun 1200 ute A15 build - Now EFI TURBO
From Perth
Dellow have an off the shelf bellhousing for W50 to A series
I think they have it as a repower option on a Hiace when people stick an A in them from memory
The W55 is completely different and they don't have those
Posted on: 6/12 12:07
From Melbored
loved them behind my 18rg celicas
and Coronas, they shift well and
handle alot more power
(still easier to source too)
Posted on: 6/13 5:12
why you are slaves to Usury https://www.youtube.com/watch?v=FEheU28ea3c The Anzac Deception not know by modern Australians http://www.anarchistmedia.org/pdf/The-Anzac-Myth.pdf ""
From Creswell, Oregon USA
The W transmission is more available than the T here. They were likely pulled out the the SR5 labeled Toyota in the USA
Posted on: 6/15 15:15
An idea doesn't work unless you do.
Instagram @MD_Machine
From Mordialloc
PM'd loosekid
Posted on: 8/8 10:40
'79 B120 (TURBO EFI A15 + 60 ser.5spd )
'83 Clubman 7 with worked A15 + 63A 5spd
'73 1200 Coupe Mild A15 5spd lsd
keep it simple
From Mordialloc
Really need one of those manifolds as there is nothing similar that I know of available here, (unless someone else does.)
The Bufalo manifolds are not made any more which was close but sits out a bit too far for my application (not in a Datsun 1200) and my fabrication skills dont quite match up to the finish and quality Im after on this second build.
Looskid PM'd again
dp
No probs now have got NFNR whatsapp No.
Posted on: 8/11 2:23
Edited by zigmondo on 2019/8/11 3:26:52
keep it simple
From Melbored
there are other DIY options with all the custom parts available these days
Posted on: 8/11 12:46
Edited by D on 2019/8/12 4:08:35
« 1 ... 5 6 7 (8)
