« 1 ... 5 6 7 (8) 9 »
Re: Datsun 1200 ute A15 build - Now EFI TURBO
From Perth
Dellow have an off the shelf bellhousing for W50 to A series
I think they have it as a repower option on a Hiace when people stick an A in them from memory
The W55 is completely different and they don't have those
Posted on: 2019/6/12 12:07
loved them behind my 18rg celicas
and Coronas, they shift well and
handle alot more power
(still easier to source too)
Posted on: 2019/6/13 5:12
From Creswell, Oregon USA
The W transmission is more available than the T here. They were likely pulled out the the SR5 labeled Toyota in the USA
Posted on: 2019/6/15 15:15
An idea doesn't work unless you do.
Instagram @MD_Machine
Parler @MDMachine
From Mordialloc Victoria 3195
PM'd loosekid
Posted on: 2019/8/8 10:40
keep it simple
Really need one of those manifolds as there is nothing similar that I know of available here, (unless someone else does.)
The Bufalo manifolds are not made any more which was close but sits out a bit too far for my application (not in a Datsun 1200) and my fabrication skills dont quite match up to the finish and quality Im after on this second build.
Looskid PM'd again
dp
No probs now have got NFNR whatsapp No.
Posted on: 2019/8/11 2:23
Edited by zigmondo on 2019/8/11 3:26:52
keep it simple
there are other DIY options with all the custom parts available these days
Posted on: 2019/8/11 12:46
Edited by D on 2019/8/12 4:08:35
From Melbourne, Australia
wow, hadnt come across this, very nice ute, love the colour... and always love a turbo a-series - neat
Posted on: 2020/4/3 6:42
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Sydney, NSW
We have to run a catch can in NSW how did you plumb it with the nfnr manifold and efi setup please?
Posted on: 2025/3/26 8:45
a basic catch can works with any manifold and with any carb or EFI. Unlike PCV which is tricky to run with most twin carby manifolds
connect both engine breathers to the catch can. That's all it takes. Rocker cover breather and block breather tube hook up to the catch can
There are more advanced oil separator cans that connect to the PCV fitting on the manifold. Instead, use a catch can with its own air filter
By the way, anyone got a picture of the NFNR Racing EFI manifold?
Posted on: 2025/3/27 8:35
From Sydney, NSW
Thanks very much appreciate the reply!
On an unrelated note I'm trying to remember what size the vacuum hose is in the top of the NFNR manifold there and on the end for the booster..
Posted on: 2025/3/28 0:28
