G5110 distributor questions
I have a few questions about the G5110 distributor.
- Is this considered to be a "high energy" (HEI) distributor?
- Is the ballast resistor supposed to be part of the ignition circuit when using it?
- What coil is appropriate?
Thanks
Posted on: 6/14 3:34
Re: G5110 distributor questions
From Hawaii, USA
G51 is the Applied Model Code for Nissan Vanette series C22 1985-1991 with A-series engine.
The G51 distributor is a Mitsubishi T4T distributor body with EI innards. It looks identical to the 1990-1994 Sunny Truck high-energy distributor, which also uses the J117/H51 ignitor, and -- because it is high-energy -- does not require a ballast resistor. Any 0.7 nominal ohm coil is right, for example, N12 Pulsar EI coil, 910 Bluebird EI coil, R31 coil, and of course the C22 and B122 EI coils, or MSD Blaster 2. Also some Mazda/Ford uses J117 so those coils would work too. I would not use the Bosch HEC715 as it draws more current being a 0.4 ohm coil
Can you confirm it has this 2-piece Mitsubishi ignitor set (marked 'J117')?
jpg  22100-G5115 ID.jpg (32.76 KB)
174_5d0313db9ae91.jpg 600X360 px
jpg  22100-G5115_.jpg (19.85 KB)
174_5d0313ec9c101.jpg 600X360 px
jpg  22100-G5115.jpg (15.85 KB)
174_5d0313f5567ee.jpg 360X600 px
Posted on: 6/14 4:35
Ok that is great info DD. I cannot confirm yet about the ignitor set as I do not have the dizzy in my hand.
Edit:
So for example this coil?
https://www.ebay.com/itm/Bosch-Ignitio ... 08e23f:g:yCsAAOSwKXFbMKHD
Posted on: 6/14 5:20
From Hawaii, USA
Bosch Red coil 0 221 119 030 is a points type it seems -- it is 1.8 ohms
And $87 is no bargain. aftermarket stalwart Standard Motor Products UF4 is $21 rockauto,com $25 Summit Racing
Looks like Superformance carries Standard Motor Products coils
Posted on: 6/14 7:19
From Las Vegas USA
So what North American model Mitsubishi cars were these dizzys in?
Posted on: 6/17 1:10
From Creswell, Oregon USA
Yeah!?
where do I get my grubby hands on one of these?
Posted on: 6/17 2:10
An idea doesn't work unless you do.
Instagram @MD_Machine
From Hawaii, USA
It is made by Mitsubishi, for Nissan. In USA it came in nothing, however, the USA E15 distributor is the same kind and I ran one on my A12. see E15 Electronic Distributor Swap
Basically just remove the gear from A distributor and put on the E distributor
Posted on: 6/18 23:37
Interestingly BProjects is selling a distributor that looks like the Chinese copies of the G5110 on ebay, and it suggests a 3.0 ohms coil in the diagram.
https://www.ebay.com.au/itm/DATSUN-120 ... A12-A14-A15-/372064200216
Posted on: 6/28 3:07
Edited by SunnyDaze on 2019/6/28 3:35:47
From Hawaii, USA
something doesn't add up
It says:
* Country/Region of Manufacture: Japan
* Brand: Nissan
And the $495 price tag matches that
But ... the photos look like a chinese knock-off
Also it says Bosch Silver Coil, which I thought was a 6V (vintage car) coil. It also says Accuspark orange coil, but they only list Black, Blue and Red http://www.accuspark.co.uk/coils.html
A 3-ohm coil is worse performance than the stock points coil, specifically weaker during engine starting
Posted on: 6/28 4:36
For the record my G5110 distributor does have the J117 Mitsubishi ignitor set. Also has a Mitsubishi marked cap and the rotor is marked with both Nissan and Mitsubishi logos.
Posted on: 6/28 9:07
