Can anyone in the US help me find this part?
1991 suzuki samurai 2wd front axle
uses leaf springs not coil springs
https://www.pirate4x4.com/forum/attach ... x4-front-axle-1.jpg?stc=1
just the axle tube housing nothing else
as I can use the 4wd bits to complete
the rest here in Japan
Was going to try this site but need to be a US resident
https://www.qualityautoparts.com/suzuk ... ai/front-axle-i-beam/1991
Posted on: 2019/6/18 6:24
Re: Can anyone in the US help me find this part?
From Creswell, Oregon USA
I scratched around on the Craigs List, but no results for my area. I can try B&R auto salvage later.
Posted on: 2019/6/18 11:13
An idea doesn't work unless you do.
Instagram @MD_Machine
Parler @MDMachine
From Stone Age somewhere in U.S.A.
McCarty Auto Parts USA-GA(Hazlehurst)912-375-2675 /800-329-7258
Nuwer Auto Parts USA-NY(Holland)1-716-537-2800
Frank's Auto & Truck Parts USA-TX(Brownsville)1-800-882-4349
Parts World USA-OK(Roosevelt) 580-639-2308 / 580-639-2242
The only ones showing in the US at wrecking yards.
GOOD LUCK!
Posted on: 2019/6/18 15:42
1983-1994 had the leaf spring live axle with front disc brakes here in USA. 1988-1994 had the bigger swaybar
gonna be expensive, probably $100 + $400 shipping
The 4WD axle is much easier to find. 2WD part cannot be converted to 4WD
Posted on: 2019/6/18 19:30
Thanks fellas for your suggestions and phones numbers!
DD great help with 83-94 models would be great but its
just the tube stripped nothing else so postage should
be no more then 120-150usd. I can source the rest here.
Tube alone weighs around 23-30 lbs.
Otherwise will have to cut and shut a 4wd one up locally
which will cost way more than sourcing a leaf sprung tube.
Posted on: 2019/6/20 5:12
looks like it will be cheaper to cut and shut a local 4wd unit to 4x2
thanks for the help guys anyways
Posted on: 2019/6/23 7:01
Edited by D on 2019/6/23 7:37:26
