(1) 2 3 »
79 B310/210 auto to 4 speed swap questions
From South Dakota USA/Trinidad and Tobago
I'm about to do a 4 speed manual conversion on my b310. Got a gearbox but cant seem to find a crossmember. Would I be able to use the crossmember from the auto? Also can I use the stock starter or does the manual have a different one?
Posted on: 2019/7/11 6:24
3NE 2NR
Re: 79 B310/210 auto to 4 speed swap questions
Starter is the same
Crossmember differs. There are four different ones
* B310 56 4-speed crossmember
* B310 60 4-speed/5-speed crossmember
* B310 60A 5-speed crossmember
* B310 Automatic crossmember
Find them at a wrecking yard. Try Car-part.com if your local yards don't have one
B310 has several holes in the body for the 4 crossmember types.
• Auto, 60L, and 60A all look similar and are 4-bolt
• 56-series looks different and is 2-bolt
Posted on: 2019/7/11 10:20
And beware: flywheels differ. Best to get the one that came with the particular 4-speed as the release sleeve varies in length with different flywheel/gearbox/engine plate combinations. If you get all those parts from the same car it should be no problem. But mixing and matching can cause clutch problems
Lastly dont forget to remove the crank spacer before you install the manual gearbox
Posted on: 2019/7/11 10:29
I believe they’re from the same car but not too sure. They both came from the same salvage yard. I’ve been searching for a crossmember on car-part.com but there’s none. Been looking on eBay as well. Might have to post a WTB ad.
About the pedals....I have a complete manual pedal box but can I just remove the auto brake pedal and swap in the manual clutch n brake pedals? I know a lot of Datsuns have the same pedal boxes and u can swap pedals like the 240z
Posted on: 2019/7/11 14:19
3NE 2NR
car-part.com takes requests
dunno about the B310 pedals. With 1200, no can do -- but Datsun since improved the pedal box design
For general information see
* Gearbox Mount B310
* Manual transmission conversion
Posted on: 2019/7/11 19:23
The cross-members turn up on yahoo auctions. There's at least one now:
https://page.auctions.yahoo.co.jp/jp/auction/j576535906
Posted on: 2019/7/12 7:18
Yo dude thanks a lot. I just bid on it👍🏾👍🏾
Posted on: 2019/7/12 16:03
3NE 2NR
Can someone tell me how to wire these up? They’re for the back up lights and top gear switch. No idea where those four wires go. It’s on a 60 series 4 speed
https://static.wheelwell.com/u/5a758ca ... b5cb4.large.jpg?width=900
https://static.wheelwell.com/u/05dedff ... f61c6.large.jpg?width=900
Posted on: 2019/7/30 14:26
3NE 2NR
the easy answer answer is that they don't need to be wired up. Will work fine without it
* To make the back-up lights work, wire up the Reverse switch
* To enable clean-air operation, wire up the Top Gear switch -- if your B310 used one in the first place
Reverse Lamp Switch has the two Green wires (Green = Lighting System). The harness in your photo looks like a Red and Green wire. Connect these to your B310's automatic transmission harness same color wires. i cant remember if its in the tunnel or in the shifter box
Top Gear switch has two Yellow wires. Which B310 do you have? FED, CAL or CAN model? A12A, A14 or A15 model? Post a pic of your aluminum underhood ID plate
jpg  05dedff0-fd0f-406a-8d21-725389ff61c6_large.jpg (106.61 KB)
174_5d40910bbeb6e.jpg 900X675 px
jpg  5a758ca1-8208-45ae-831a-7568a0ab5cb4_large.jpg (115.98 KB)
174_5d4091290aa79.jpg 900X675 px
Posted on: 2019/7/30 19:52
It’s a California spec A14 car. Also how does the starter have to be wired?
Posted on: 2019/7/30 21:15
3NE 2NR
(1) 2 3 »
