Reverse Lamp Switch
From Datsun 1200 Club
Categories: Transmission | Lighting System
The Reverse Lamp Switch is the little switch in the transmission that causes the reverse Tail Lights on the back of the 1200 to light up when you put the gearshift lever in the R position. Reverse Switch on a 1200 gearbox is located on the shifter extension of tail housing very near the top of the housing. And different location for other transmissions.
Location
56-series Gearbox
Reverse switch location (A12 4-speed)
14985.jpgAlbum 14985
The Reverse switch is same part number as Top Switch.
1200 4-speed & 5-speed
Pinks arrows: reverse lamp switch
19048.jpgAlbum 19048
3-speed reverse switch points straight back (Blue arrow)
22140.jpgAlbum 22140
60-series
A14/A15 4-speeds & B310 5-speeds
Reverse Switch is near bottom of 60-Series Transmission
25456.jpgAlbum 25456
1676.jpgAlbum 1676
63-series
B210 A14 5-speed
Reverse Switch is near bottom of 63-Series Transmission 5-speed
24141.jpgAlbum 24141
Custom
When fitting a 60-series 5-speed into a 1200, there may not be enough room for the switch -- as it right where the mount is.
22724.jpgAlbum 22724
Solution 1: Plug the hole for the exising switch. Use Nissan 32108-18100 PLUG, or a custom made plug like this:
21070.jpgAlbum 21070 21071.jpgAlbum 21071 21072.jpgAlbum 21072 21073.jpgAlbum 21073 21074.jpgAlbum 21074
Solution 2: Replace with a shifter switch:
21932.jpgAlbum 21932 277_4d5cdb9e56c84.jpgPost 357137
Solution 3: modify the tunnel:
5008.jpgAlbum 5008 5009.jpgAlbum 5009
Solution 4: Using a hole saw, cut a hole right beside it in the tunnel so it has some room to fit and to move. then feed wires to it through there. Cover the hole with a flexible boot.
ong vs short type of backup light switch
22137.jpgAlbum 22137
K12
32005-K121A Rev Lamp B110 $33.70 USD
Used by all Datsun 1200
Most 60-series 4-speeds B210/B310
FSW560L 60-series 'dogleg' 5-speed B310
Some FSW560A 60-series 5-speed B310
Also used in early 4TH-gear switch (USA B110)
Aftermarket
* BWD S9254 (w/spade terminals)
* ACDelco E2202
* ACDelco E2228D
* Master Pro 2-8943 (w/bullet terminals)
* Original Engine Management 8943
* Standard Motor Product/Intermotor LS325
* AirTex/Wells 1S5440
Back Up Lamp Switch
K10
32005-K102A Switch Rev Lamp $36.47
Used by some FSW560A 60-series 5-speed B310
Alternate OEM Part Numbers:
32005-K1001
32005-K1004
32005-K102A
32005-M0200
32005-M2105
88923307
JA442
32005-21000
32005-K1004
Nissan 32005-K102A ($53.72 2025)
31033.jpgAlbum 31033
Aftermarket
* ACDelco E2204
* KEMParts NS157 $7.56 USD
* Original Engine Management 8999 (w/spade terminals)
* AirTex/Wells 1S5792
fits various 56-series, 60-series, 63-series and 71-series
* A12A/A14/A15
* L16/L18/L20B
* L24/L24E/L26/L28E/L28ET/LD28 Diesel
* E15
* Z20/Z22/Z22
* SD22/SD25 Diesel
56-series
Backup Lamp Switch for A10/A12 powered vehicles.
32005-K1214 COMP-SWITCH REVERSE LAMP
32005-K121A Rev Lamp B110 $33.70 USD FS4W56L
superceded 32005-H5000 COMP-SWITCH REVERSE LAMP
replaced 32005-21101 COMP-SWITCH REVERSE LAMP
replaced 32005-21100 COMP-SWITCH REVERSE LAMP
* ACDelco E2202
* ACDelco E2228D
26025.jpgAlbum 26025
B120 Datsun 1200 Pickup
32005-21000 SWITCH COMP.-reverse lamp 3 speed
32005-21100 SWITCH COMP.-reverse lamp 4 speed
32005-21101 SWITCH COMP.-reverse lamp 4 speed
32010-G1651 -8910 B120 FSW56A
replaced 32005-21101 SWITCH ASSY-REVERSE LAMP
B10 Datsun 1000
32005-21100 ASS'Y-SWITCH, reverse lamp 4 speed
32005-21000 ASS'Y-SWITCH, reverse lamp 3 speed
replaced (not interchangeable) 25310-89900 ASS'Y-SWITCH, reverse lamp 3-speed
32108-18100 PLUG-reverse lamp switch (up to '68-Sept.)
32005-K121A Switch Rev Lamp $33.70 USD
superceded 32005-K1202 SWITCH COMP-REVERSE LAMP 4-SPEED(A12) B310
superceded 32005-K1201
60-Series
4-speed
superceded 32005-K1202 SWITCH COMP-REVERSE LAMP 4-SPEED(A14,A15) B310
5-speed
superceeded 32005-K1202 SWITCH COMP-REVERSE LAMP B310 -0779 [FS5W60L 'dogleg']
superceeded (interchangeable) 32005-K1201
superceeded (interchangeable) 32005-H5000
32005-K1000 SWITCH COMP-REVERSE LAMP B310 -0779 [FS5W60L 'dogleg']
superceeded 32005-H5000 SWITCH COMP-REVERSE LAMP B310 0879- [FS5W60A]
replaced (not interchangable) 32005-K1000
superceded 32005-K1002 SWITCH COMP-REVERSE LAMP B310 0879- [FS5W60A]
superceded (interchangeable) 32005-K1001
superceded (interchangeable) 32005-K1000
バック ランプ スイッチ
63-series
For B210 5-speed, which debuted April 1976 (1976-1/2 model year)
superceded 32005-K1000 COMP-SWITCH,REVERSE LAMP 5-SPEED(COUPE) B210 0476-
Automatic
In automatic-transmission 1200s, the backup lamp switch is in the Automatic Shifter, not in the gearbox.
Reverse Lamp is powered off the 10A IGN Fuse. It is grounded at the back combination tail lamp bolt.
22141.jpgAlbum 22141
Swap Notes
The location of the Reverse Switch can differ between all the different transmission. It is generally a problem when fitting any 60-series or 63-series gearbox in to the small 1200 manual tunnel. The reverse-light switch is right where the Datsun 1200 chassis x-member mount is.
To use a shifter mounted switch, see this POST 60A reverse switch ???
9665_4cea3fb22f91d.jpgUpload click to view
For other options, see 60-Series Transmission#Reverse Switch
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Reverse_Lamp_Switch"
This page has been accessed 45,767 times. This page was last modified 03:40, 24 October 2025. Content is available under Datsun 1200 Club.
