(1) 2 3 »
A series auto bell housing
From Adelaide
Any one know how long the a series auto bell housing is? i.e. the measurement between engine and auto box? I'm starting to think about how to fit my w5x Toyota gearbox to my a15.
Posted on: 2019/7/26 5:24
1200 Coupe A15E - ITB
Lamb Daiquiri - a man's cocktail!
Re: A series auto bell housing
From Tamworth, NSW
Can measure tonight. Have one sitting in the shed.
Posted on: 2019/7/26 5:57
Project coupe:
Just drive it
From Adelaide
Cheers, I just did some rough measurements on the two boxes in the shed, the standard 4 speed has the input shaft protrude ~16mm from the bell housing. The W5x box has the input shaft shorter than the bell housing by ~3mm and the bell housing it's self is ~ 161mm long.
If/ when I get to it I can take the bell housing to work and measure it on the flat table with a height gauge. Concentricity is more critical though.
Posted on: 2019/7/26 11:57
From Perth
Steel case or Supra ?
Posted on: 2019/7/26 12:17
From Adelaide
Alloy case, w55-58, I'm not sure, bought it years ago. Alloy plate so an earlier one, counting ratios is apparently the only way to tell. I haven't done that yet.
I can post a pic if there's any Toyota buffs.
Posted on: 2019/7/26 14:00
From Adelaide
Ideally the auto bell would be less than about 135mm that would leave enough room for an adaptor without any other additional parts, otherwise I may as well use what I have. Either a cut and shut or adaptor plate and an extra piece to move the spigot bearing.
Posted on: 2019/7/28 3:54
From Perth
Thats alot of box for an A series
I've used the T50 successfully
I'm going for a W50 (steel case celica) for the next engine
Posted on: 2019/7/29 11:46
From Adelaide
You're not wrong, it's hard to imagine an A15 ever breaking it regardless of how much extra air you pump into it! Should be bullet proof. Be interesting fitting it in the tunnel though. I might be after a bigger one.
Posted on: 2019/7/29 12:10
w50 are actually stronger than w55 and w57
found in 2m 6cyl engines in crowns and used
behind very beefed up holden v8s in their day
Posted on: 2019/7/29 15:35
From Queanbeyan nsw 2620
Hey guys dont mean to high jack the convo but does anyone have a bellhousing for sale to bolt up to a jatco box not the air cooled box unless its bolt up to both the jatco and A series engine as i no the boxes look different on the out side
Thanks
Posted on: 2019/7/31 7:54
(1) 2 3 »
