Browsing this Thread:   3 Anonymous Users
« 1 (2) 3 »
Re: Gunson's colortune
From Stray-ya
My gunsson's arrived on the weekend
Man that thing is cool.
turns out I am very rich right through the range.
Posted on: 2006/3/27 11:38
Hi Grunterhunter, how do you use the Colortune spark plug to check the entire engine range? I thought you couldn't drive around with it in the engine since the plug runs much hotter than the normal plugs.
Posted on: 2006/3/27 23:55
From Stray-ya
Yeah, sorry, bad choice of words there. It is rich right through the range just reving it (not under load)
They warn against prelonged use, because of the heat range of the plug. I cant remeber off hand if it was hot or cold so I'll take your word on that one.
But apparently using it on a dyno is okay -just in case you have a dyno but no analytical gear to go with it
so potentially you could do a quick run around the block with the bonnet off and the little viewer scope pointed towards the driver .
Posted on: 2006/3/28 2:52
From Stray-ya
The colortune says rich, right through the range free revving (bright orange flame), but I just had my car dynoed and I was running up to 13.5-14 AFR from 4000rpm up when it was under load.
Lean through the top end just as I had suspected from the start!!!!!
And I was about to get smaller jets based on the colour tune Damn thing could have cost me an engine (or at least a valve or two)
A-15 dyno sheet
Posted on: 2006/4/3 11:35
What do you mean by lean?
That's rich. Stoich is 14.7. 13-14 is rich, but not overly so. 15 would be lean. See air fuel ratio encyclopedia entry:Quote:
in Naturally Aspirated engines maximum power is frequently reached at AFR's ranging from 12.5 - 13.3:1
Posted on: 2006/4/4 5:40
From Stray-ya
We're on the same page dd, That's exactly what I said to the mechanic, but he reckoned I wanted to keep them closer to 12.5-13 for a safe tune. the exact quote was: "you will probably drop a few hp, but if you keep running it the way it is it may cost you an engine"
Posted on: 2006/4/4 12:47
For you old-school guys here's one for sale $90 opening bid
http://buyee.jp/item/yahoo/auction/p702080989?lang=en
COLORTUNE is a special British-made structure, direct visual while carburetor and engine flame of the combustion chamber of the engine during start-up it is a tool that allows the adjustment
jpg  Gunson's Colortune kit.jpg (73.74 KB)
174_5d61b0b030400.jpg 640X480 px
jpg  Gunson's Colortune.jpg (97.32 KB)
174_5d61b0be5eb2f.jpg 640X480 px
jpg  Gunson's Colortune attachments.jpg (67.08 KB)
174_5d61b0c87ce00.jpg 640X480 px
jpg  Gunson's twin carb sychro.jpg (105.33 KB)
174_5d61b0d5e6684.jpg 640X480 px
jpg  Twin carb sychro.jpg (61.66 KB)
174_5d61b0dd052bc.jpg 640X480 px
jpg  Fuel system fault diagnosis chart.jpg (84.85 KB)
174_5d61b0eaf2eea.jpg 640X480 px
jpg  case.jpg (45.98 KB)
174_5d61b0f2a0060.jpg 640X480 px
Posted on: 2019/8/24 22:50
From Sydney Australia
I use innovate motorsports LM series and datalogging useful as for road use dyno tuning is just a starting point as it often ends up too rich for road use and there is nothing like tuning for real world useage
Posted on: 2019/11/2 22:09
Ah the good old days are gone where seat of the pants, sound, frequencies, exhaust smell and checking plugs was an art form for tuning by those refined for cars analog sensing humans.
I miss the old guys that could tune anything without a laptop or techno gadget.
Posted on: 2019/11/3 10:13
innovate motorsports LM series just read the meter and manually tune it to read 14:1 then it won't be too rich for road use though maybe still tune it to 12:1 at full throttle
Posted on: 2019/11/3 22:59
« 1 (2) 3 »
