Tachometer
This is the 1972 tachometer, and it's a GX by the 6800 RPM redline
jpg  H34 GX.jpg (83.12 KB)
174_5d61cca64f140.jpg 998X999 px
jpg  H34 GX-.jpg (112.80 KB)
174_5d61ccaf8f96e.jpg 1169X1200 px
jpg  H34 GX_.jpg (81.99 KB)
174_5d61ccb70965d.jpg 928X929 px
Posted on: 2019/8/25 0:48
Re: Tachometer
1970-1971 tachometer H18 (AMC = originally designed for coupe)
Posted on: 2019/8/25 1:11
Re: Tachometer
This one's a bit of a puzzle ... maybe aftermarket? Or a later dealer accessory?
* Doesn't have the wiring loop as other 1200s have -- it has a single signal wire
* 1970 style lens attached
* 1972 style display (colors & font)
* does not have the 1972 style attachment stay
jpg  non-loop old-lens new-style TACH.jpg (67.53 KB)
174_5d61d391e3eae.jpg 970X604 px
jpg  non-loop old-lens new-style TACH b.jpg (79.45 KB)
174_5d61d39be88e8.jpg 1200X800 px
jpg  non-loop old-lens new-style TACH c.jpg (28.33 KB)
174_5d61d3b056ded.jpg 558X572 px
Posted on: 2019/8/25 1:17
Re: Tachometer
hi.
how to test the tachometer off the car?
Posted on: 2019/8/25 15:33
Re: Tachometer
From Sydney
I think that at some point someone has disassembled the wires. the "loop Wire" is there, just not hooked up in the right place. The black wire has been fastened to the Loop wire location in error.
I can double check as I have one on these tachos.
Posted on: 2019/8/26 2:39
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
Re: Tachometer
Good question. The easiest way to test is to carry it to your running 4-cylinder car
Three wires:
* Black wire to batttery NEG (-) terminal
* Yellow wire to battery POS (+) terminal
* Black/White loop wire. Disconnect wires from COIL + terminal. Connect wires to one end of black/white loop. Connect other end of black/white loop to coil
Start engine and observe
You can also use a 6-cylinder car it will just read 2/3 of normal
Posted on: 2019/8/26 5:57
Re: Tachometer
thank you.
Posted on: 2019/8/26 10:06
Re: Tachometer
From Beautiful Sunny (sic) Melbourne
Or will it?
Does it count the number of pulses received from the coil and divide by 4 (or 6 or 8?) and display that as rpm? Actually it would divide by 2, 3 or 4 as there are 4 pulses per 2 revolutions with a 4 cylinder engine (4 cylinders, and 2 revolutions in a 4 cycle engine).
Try it and see?
Posted on: 2019/8/27 2:04
Re: Tachometer
good question. I forget if it reads 1/2 or double. Apparently you can change the capacitor or the resistor (inside the tachometer) to get it to read correctly on a different size engine
Posted on: 2019/8/28 0:38
Re: Tachometer
here is how the tachometer mounts to the dashboard facia
The blank plate can be removed and the tachometer bolted on
Three screws go in the holes (red arrows) and fasten the tachometer to the facia. It is possible to bolt/unbolt it while it's in the the dash -- by reaching up from below and fiddling with the tiny screws, but is not easy. Much easier and less error prone to just remove the facia in the first place
jpg  Tachometer mounting.jpg (52.00 KB)
174_5d65daa39a91c.jpg 992X864 px
jpg  clock or tacho mounting 26029x.jpg (37.57 KB)
174_5d65dab2369bf.jpg 560X520 px
jpg  Gauge mounting to back of facia plate cgb2.jpg (56.87 KB)
174_5d65dac10c42d.jpg 1200X448 px
Posted on: 2019/8/28 2:38
