« 1 ... 24 25 26 (27) 28 »
Re: DEMAC's 1200 UTE
From Melbourne, Australia
Very nice mate
Posted on: 2019/9/14 12:29
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Mordialloc Victoria 3195
Missed opportunity to flare the Guards
Posted on: 2019/9/15 3:46
keep it simple
From MOOROODUC. Victoria
New shoes - plasti dip white; they may need a coat of clear to protect on the dirt roads
TRX Rims to come up for sale with centre caps and nuts - AFTER Nickmitty sells his :)
jpg  New Shoes.jpg (78.39 KB)
8710_5df32edf6d057.jpg 1008X490 px
Posted on: 2019/12/13 6:26
3 years since updating this particular thread,
I decided to remove the side tabs since my tonneau cover doesn't use them.
also wanted to freshen up the sides.
Then you know how sometimes you can't leave well enough alone? ... I picked at a crack in the botton left corner of the passenger rear wheel arch and it turned into an exploration expedition - oh dear bog almost half an inch thick and very little metal holding it!
out with the MIG
jpg  remove side tabs1.jpg (111.32 KB)
8710_63ae80c7c9919.jpg 756X756 px
jpg  rust in sill 1.jpg (125.45 KB)
8710_63ae80d6a7ac2.jpg 756X756 px
jpg  rust in sill 2.jpg (121.40 KB)
8710_63ae80de0e65d.jpg 756X756 px
Posted on: 2022/12/30 6:15
Finished...ish
just the sanding and polishing to go once it's cured
There was a bit of work to do on the drivers side rear bottom of wheel arches. The problem with living on a dirt road is that the car perpetually has dirt underneath and it holds the moisture for rust to form... oh well
jpg  2023 paint refresh 2.jpg (111.26 KB)
8710_63c20ed42fb07.jpg 756X756 px
jpg  2023 paint refresh 3.jpg (79.29 KB)
8710_63c20ee03546d.jpg 756X756 px
jpg  2023 paint refresh 5.jpg (90.61 KB)
8710_63c20efa642b6.jpg 756X756 px
jpg  2023 paint refresh 6.jpg (76.98 KB)
8710_63c20f0d742fe.jpg 756X756 px
jpg  2023 paint refresh 1.jpg (78.25 KB)
8710_63c20f3cf1530.jpg 756X408 px
jpg  2023 paint refresh 8.jpg (111.64 KB)
8710_63c20f4f95d4e.jpg 755X742 px
Posted on: 2023/1/14 2:12
CA18DE.....
CYL1 160
CYL2 20
CYL3 20
CYL4 175
sad face
Posted on: 2023/4/23 9:15
Time for the CA18DE + T build
Posted on: 2023/4/25 14:04
Maybe not ...
A very low reading (10 - 30) sometimes means a stuck valve. If you get it un-stuck it may work perfectly well
On the other hand, since the two low-reading cylinders are next to each other, it's more likely to be a blown head gasket
Do an air-leak to test to confirm the problem -- without needing to disassemble the engine. Is air leaking out the manifold (stuck valve) or leaking out the radiator (blown gasket)? A blown gasket often can be fixed without any machining of the head. The tolerance of the A-series and of the twin-cam KA24DE are both at 4 thousands of an inch warp, anything less than that doesn't need the head re-machined. Just put a new gasket on it
Posted on: 2023/4/25 22:08
CA18DE Engine rebuild
Blown and scorched between 2 and 3.
Head is being done.
Bores pitted.
It's been hot tanked, deck to be checked, getting measured tomorrow for bearings, rebore, new internals, etc, etc, etc.
Doing it right, hopefully just once.
Posted on: 2023/6/4 7:37
Who’s doing the rebuild for you?
Posted on: 2023/6/4 9:48
