« 1 (2)
Re: murry the morry
From Kelmscott Western Australia
photos
jpg  rsz_img_0287.jpg (191.34 KB)
13822_5d8f360908fe1.jpg 2016X1512 px
jpg  rsz_1img_0289.jpg (191.03 KB)
13822_5d8f37f9562e4.jpg 2016X1512 px
jpg  78F0AA81-DA57-4DC5-8D52-21ED54F3BC56_jpeg.jpg (49.26 KB)
13822_5d8f3866e55f2.jpg 375X281 px
jpg  0863D7A3-5D36-4254-AF3F-050B2AF7EA8D_jpeg.jpg (85.87 KB)
13822_5d8f3877d7f85.jpg 480X360 px
jpg  EC8CEEA0-EE53-41B2-9661-CA9FA8A735CD_jpeg.jpg (47.09 KB)
13822_5d8f3886831f3.jpg 480X360 px
Posted on: 2019/9/28 11:40
Re: murry the morry
Very nice looking installation. About that clutch, is it the 200mm version? Looks like it takes up the entire flywheel
Posted on: 2019/9/28 21:59
Re: murry the morry
180b clutch
A12 flywheel machined to take the pressureplate and disc
Posted on: 2019/9/28 23:44
71 Datsun 1200 ute with A14 fuel injection and T50
59 Morris minor ute with A15 fuel injected with intercooled turbo
Re: murry the morry
Nice. 180B (Datsun 610) uses a 200mm clutch
This is how I was told to modify the A12 flywheel:
1. machine the step out of it (mill it totally flat)
2. drill new holes closer to the rim for the larger pressure plate
Better yet, mill the edge down to re-create the step. The step is not needed -- with a flat surface the clutch will wear out a bit sooner, but still work good perhaps for several years
See L-series clutch on A-series flywheel
Posted on: 2019/9/29 1:26
Re: murry the morry
"Even if the ECU won't handle it, the system can be richened or leaned by adjusting the fuel pressure at the rail"
LOL if only later systems where that easy!!! Always dreaded all ecu systems to modify like we can mod carbies. Especially after seeing so many tuners and customers spending weeks, months and years on them.
The datto ecu setup sounds like a heaven sent beauty just like datsuns "simple and concise"
Posted on: 2019/9/29 1:45
Re: murry the morry
Have done some more mods since last post
i fitted bigger computer out of a z20 engine runs bit better just needed some bit of adjustment
runs well on a A14 ecu even on boost
Posted on: 2021/1/20 7:45
Re: murry the morry
two years on i have done changes to my ute
Made homemade injection manifold with turbo running 10psi
Photos come after
jpg  rsz_c774ad64-69d1-4004-b260-ab1dcc8acc73.jpg (198.33 KB)
13822_64ced4cbd17d1.jpg 1008X756 px
Posted on: 2023/8/5 23:58
« 1 (2)
