LED bulbs
Anyone using LED lights?
Posted on: 2019/10/4 13:44
Re: LED bulbs in dash
For the dash, there are only 3 illumination bulbs
* speedo illumination (two bulbs)
* cluster gauge illumination (one bulb)
they are T10 bulbs (W2.1x9.5d base) or "miniature wedge"
original spec is 2.7 watt (type 161)
can also use T3-1/4 glass with T5/W5W base (max. O.D.: 10.3 mm)
This same bulb (Nissan 26261-89902) is used by the new GT-R
jpg  central Cluster bulb GREEN cover.jpg (80.71 KB)
174_5d9743367cb3a.jpg 1024X768 px
jpg  central Cluster bulb GREEN cover removed.jpg (56.77 KB)
174_5d97433d3b9df.jpg 1000X576 px
jpg  Speedometer top & bottom bulbs.jpg (76.54 KB)
174_5d9747d72954e.jpg 1000X750 px
jpg  toshiba twist-lock socket.jpg (15.34 KB)
174_5d9747dfdd04b.jpg 400X612 px
Posted on: 2019/10/4 14:25
LED bulb headlights
Replace the 7" round sealed beam headlights with LED versions
* For looks
* For lower power usage (?)
* Not for brightness. H4 headlights can be brighter
Like these H4 diamond-type from https://www.jaganlamps.com
jpg  JAGAN glass lens with city lights and replaceable 9003 bulbs.jpg (174.21 KB)
174_5d97bce050ffb.jpg 1600X901 px
jpg  Diamond H4.jpg (153.01 KB)
174_5d97bcf323dc8.jpg 883X1463 px
jpg  Diamond.jpg (150.54 KB)
174_5d97bd19c8846.jpg 920X1455 px
Posted on: 2019/10/4 22:44
Re: LED bulb headlights
Or how about Angel Eyes (halo bulbs). NOTE: Only legal to light up the LED rim when off-road say at a car show
levey's Datsun 1200 with home-made angel eyes
Posted on: 2019/10/5 23:59
Re: LED bulbs
any hid for 7 inchers or is the only choice led besides h4?
Posted on: 2019/10/7 12:10
Re: LED bulbs
HID is a whole 'nother story. HID is a type of arc lam
No need for it as sealed beam Halogen is available in high-lumen versions. Likewise H4. And LED headlights can be even brighter while using the least power. The only down downside is LED headlights are ugly
Posted on: 2019/10/8 10:25
Re: LED bulbs
Wagner H6024LED is a USA DOT-compliant headlight for right-hand roads
* brighter than H6024 Halogen
* wider beam
* whiter beam (higher color temperature)
jpg  H6024LED_front.jpg (46.32 KB)
174_5d9c6a6d17087.jpg 600X600 px
jpg  H6024LED_back.jpg (147.03 KB)
174_5d9c6a76840f8.jpg 1500X1500 px
Posted on: 2019/10/8 11:53
Re: LED bulbs
From Seattle ,WA.
bought lots of lights for the coupe from Superbright LED, all lights except perhaps license lamp & headlights I have LED's in
https://www.superbrightleds.com/
pretty reasonable $$ place
Posted on: 2019/10/8 15:52
Re: LED bulbs
Interesting site
They don't list headlights for Datsun 1200, but have other bulbs
The room lamp is the too-long version. It will fit if you bend the lamp tabs out a bit
DE3175 LED Light Bulb
3mm LED Festoon Bulb
3022 Base
30mm
3 cm(1.18") x 1.05 cm(0.41") x 1.05 cm(0.41")
29mm is the stock Nissan 26736-89902
Which color to buy?
* Cool White 6000K
* Natural White 4500K
* Warm White 3400K
* Red
* Blacklight
* Green
* Blue
The stock room lamp has a frosted cover so I suppose the cool white bulb is not needed? Maybe "natural white" would be closer to the stock incadescent bulb?
Can-bus version or normal version???
Then what about beam angle?
* 30-60 degrees
* 61-120 degrees
* 120-150 degrees
Looks like you have to turn the bulb to a certain orientation to shine the light down
The surprising thing is most bulb vendors don't give brightness specification. For this room lamp it says it is "comparable wattage" to a 3-5 watt bulb. The Nissan version is a 10W bulb, so this LED version probably is not as bright. But SuperBrightLeds also list 21 lumens for the Cool White version. I wonder what the stock version is
jpg  DE3175.jpg (30.02 KB)
174_5d9d188229539.jpg 585X480 px
jpg  DE3175 white.jpg (32.42 KB)
174_5d9d188e59315.jpg 585X480 px
jpg  3022 dimensional drawing.jpg (98.29 KB)
174_5d9d189b59acf.jpg 950X734 px
jpg  DE3175 amber compared to DE3175 Incadescent.jpg (89.73 KB)
174_5d9d18bec8538.jpg 800X800 px
jpg  Wagner 12100 (type DE3175).jpg (23.51 KB)
174_5d9d18ca43bf4.jpg 600X600 px
Posted on: 2019/10/9 0:16
Edited by ddgonzal on 2019/10/9 0:53:11
Re: LED bulbs
From Seattle ,WA.
I dont remember exactly which bulbs I bought but I replaced almost everything , turns, side markers, reverse, brake, dome, dash light - those bulbs came a little long so I sanded them down to fit the socket on a bench sander, worked fine. Turns you need a flasher for i believe.
Overall they were incredibly cheap comparatively to any parts store, marine or auto. You can buy LED's anywhere now but still expensive
Cool white has a bluish hue
Warm white = yellowish
bought brakes in red, turns in amber, etc...
Posted on: 2019/10/9 17:54
