what type/brand of Ignition is this?
From Seattle ,WA.
Its on an early A dist. from a motor Im trying to "bench start", I don't have a control module unless its self contained like Pertronix. Its a disc style running thru 2 pickups, 3 wires - black, gray, white. Hall effect type maybe??
If I cant use this can a late A model matchbox dist. be swapped in? if so, what's to do about the mount plate, doesn't align with early A block.
Hey - how does one load pic's from an iphone in a post?
thanks!
jpg  dist2.jpg (22.86 KB)
3475_5d9a6dd86272f.jpg 320X240 px
jpg  dist.jpg (18.57 KB)
3475_5d9a6de3d394f.jpg 320X240 px
jpg  1200.jpg (24.71 KB)
3475_5d9a6def99a86.jpg 320X240 px
jpg  dist3.jpg (21.19 KB)
3475_5d9a6e7c21391.jpg 320X240 px
Posted on: 2019/10/6 23:42
Re: what type/brand of Ignition is this?
Photo upload instructions for iPhone. More normal size pics may help us identify what ya got
Posted on: 2019/10/7 4:16
From Seattle ,WA.
maybe these are better.
I'm recalling the offsite photo issues, store them on Photobucket or somewhere then have to go there & copy the url's into the posts.
I've used other forums where you can upload directly from the photo album on your phone directly into the post, that's not possible on this site?
jpg  dist4.jpg (64.99 KB)
3475_5d9ab873bfa65.jpg 640X480 px
jpg  dist5.jpg (74.32 KB)
3475_5d9ab87fbecff.jpg 640X480 px
Posted on: 2019/10/7 5:03
Yes it is possible. The link I posted talks about it. Here it is again: Photo upload instructions for iPhone
Posted on: 2019/10/7 9:58
Yeah I can see it now. Looks like Lumenition conversion. Needs an external box
The bigger problem is the vacuum advance is not connected, so the timing will randomly vary by 50 degrees while running
A late-model distributor fits -- just modify the hold-down plate to cut out a bit of the slot
The yellow marks show where you should cut (or you can cut it twice, like I did ). This lets the 5-degree timing line up in the middle of the adjustment range, with the new distributor pointing the same direction as the original distributor
for the 210 distributor
* Head of T: "C" connector goes to coil negative
* Stem of T: "B" connector goes to coil positive
Posted on: 2019/10/7 10:17
From Seattle ,WA.
I think I figured out what system this is - Crane Optical LED iginition, heres a link to Amazon show all the parts & pieces.
Yes Im missing the control module, maybe it'd be worth buying the kit, about the same price as a Pertronix conversion.
Anyone ever run one or know much about these?
https://www.amazon.com/Cams-3000-0231- ... fRID=A8W4Z759WNQ5MZDMV3R2
Posted on: 2019/10/7 19:12
The Datsun 210 system is better
* Maintenance-free VR trigger
* high energy ignition
* better spark separation
Posted on: 2019/10/8 10:00
From Seattle ,WA.
I hate chopping up/modifying OE parts so I'll probably make a copy of a new mount plate and use the matchbox dist.
Posted on: 2019/10/8 15:49
