« 1 2 (3) 4 5 6 ... 20 »
Re: wagon body work
From melbourne
starting on engine bay
remove battery tray
1 very nasty rust hole ,top passenger side corner
jpg  32.jpg (77.73 KB)
14887_5de82a9714bff.jpg 720X960 px
Posted on: 2019/12/4 21:52
Re: wagon body work
Cybertruck body is 301 stainless & 40k! enemies wont hear it :)
Clearly what was communicated by the previous muppet was wrong
however for a 1200 wagon, most only see worse rust than what you
are showing so far here. In fact "most" 1200s have worse.
Straightening all the body will be the single most consuming
part of the costs vs the little patching and welding.
As a restomod, prob consider a brighter shade with a period interior.
It is easier to see in bad weather and in general motoring most will
be able to spot it better than darker shades.
POR 15 WhiteCote is the toughest paint Ive come across, couldnt scratch it
with keys at all could only barely put a cut using a new box cutting blade.
Good luck, work done looks good.
Posted on: 2019/12/5 3:02
Edited by D on 2019/12/5 3:35:28
Re: wagon body work
From melbourne
Day 8
jpg  34.jpg (84.79 KB)
14887_5de97e7e3bc77.jpg 720X960 px
jpg  35.jpg (77.13 KB)
14887_5de97e86ef5ad.jpg 720X960 px
Posted on: 2019/12/5 22:02
Re: wagon body work
From melbourne
Im actually looking forward to next week , when the cutting starts .
The front passenger sill will be cut out to reach the hole in the upper firewall and to cut the side . Water naturally travels down and so does the rust , leaving its mark from top to bottom . Most likely the dash needs to be removed . In the engine bay between the shock / strut and firewall top corner is a hole the size of your fist. It goes straight through and also goes down the pillar to the bottom sill both sides. Besides a hole in each quarter of the the floor , the rear shelf from the wheel arch to the rear is rusted of on right side. I havent been able to find a replacement part as they only supply ute tray patches. The channel are different. The top of the rear window lip will be cut out and a new piece made and welded back in. and the rear sill too. There will be about a dozen patches done
jpg  rust.jpg (36.98 KB)
14887_5de99ffc5ca6a.jpg 825X315 px
png  rear.png (199.14 KB)
14887_5de9a00b30fa0.png 451X603 px
Posted on: 2019/12/6 0:25
Re: wagon body work
From melbourne
engine bay hole
jpg  bay hole 1.jpg (113.30 KB)
14887_5de9a156349fb.jpg 816X482 px
Posted on: 2019/12/6 0:31
Re: wagon body work
From melbourne
More bad news today
Was called down to discuss the floor, its worse than thought. Seems someone
decided to pop rivet pieces in the floor . After closer inspection , entire floor needs to be replaced.
On a lighter brighter note. Engine bay epoxied
jpg  36.jpg (89.48 KB)
14887_5de9c8b63e44b.jpg 720X960 px
jpg  38.jpg (65.82 KB)
14887_5de9c8c31f780.jpg 540X960 px
Posted on: 2019/12/6 3:19
Re: wagon body work
From melbourne
DAY 9
Today cutting corner of sill out to see damage
Explains why bottom pillar and floor rotted
jpg  41.jpg (37.99 KB)
14887_5ded74867fe5d.jpg 290X481 px
Posted on: 2019/12/8 22:09
Edited by nickmitty on 2019/12/9 0:03:51
Re: wagon body work
From melbourne
looks nasty
jpg  43.jpg (82.51 KB)
14887_5ded8f2b2306b.jpg 720X960 px
Posted on: 2019/12/9 0:02
Re: wagon body work
From melbourne
Day 10
nearly ready for welding
jpg  44.jpg (82.36 KB)
14887_5deefc4588d64.jpg 720X960 px
jpg  47.jpg (72.48 KB)
14887_5deefc6fe9671.jpg 720X960 px
jpg  48.jpg (63.23 KB)
14887_5deefc7dcbd27.jpg 720X960 px
Posted on: 2019/12/10 2:01
Re: wagon body work
From melbourne
Needs a drain hole
think using 1.2mm gauge sheet
jpg  50.jpg (68.16 KB)
14887_5def1e4c944ba.jpg 720X960 px
Posted on: 2019/12/10 4:26
