Twist Test????
From MOOROODUC. Victoria
So the new Sedan project is started and the welding is continuing ... at my skill level ... the Engineer says he wants to get a 1200 twist tested to know that it will withstand the "extreme power" that I am planning (less than 200kw).
The test is the same as the one they do when cars get converted to open tops.
Anyway, has anyone had a sedan shell tested before? If so can you share the report?
Otherwise the Yella Terra shell gets to do it - the test is not destructive unless it fails in some unforeseen major way
I will ask for a report to share so that no-one else has to fork out a grand
Posted on: 2020/1/31 6:00
Re: Twist Test????
From Mordialloc Victoria 3195
I think its called a Beam and Torsion test. The Clubman 7 builders need to pass it to get registration - pretty crazy the amount of torsional twist they subject the cars chassis to
Posted on: 2020/1/31 21:02
keep it simple
Re: Twist Test????
He came in with a Datsun and leaves with a pretzel 🥨
Posted on: 2020/2/4 8:28
Re: Twist Test????
From Melbourne, Aus.
How did the test go?
Posted on: 2020/2/26 7:12
Re: Twist Test????
Delivered the yella shella on Monday ... they won't be able to get to it until late next week
Posted on: 2020/2/26 10:53
Re: Twist Test????
Do you have any test results yet?
Posted on: 2020/3/12 4:58
Re: Twist Test????
From Melbourne, Australia
BUMP!
Posted on: 2020/4/3 6:32
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: Twist Test????
No test results yet....they are too busy and i am not in a hurry.
Posted on: 2020/4/3 9:50
