« 1 ... 88 89 90 (91) 92 93 94 ... 96 »
Re: Super Bee KA24DR Sedan
circle track ka24? please share somewhere about it!!!
Posted on: 2020/1/31 9:15
From Snohomish, WA USA
Here is a couple of Mini Stock race cars. Obviously smaller than the Super Stocks. They run 3/8 or 5/8 mile oval track.
The guy who builds these cars also builds my special parts for my car. I do a lot of my own fabrication but some stuff he gets done. Never would have been able to get this far without him. 🙂
jpg  IMG_1145-512x384.jpg (95.88 KB)
39_5e35071858545.jpg 512X384 px
jpg  FB_IMG_1580530082481.jpg (78.59 KB)
39_5e350ad04e040.jpg 720X960 px
jpg  jpeg-imag.jpg (123.88 KB)
39_5e350b481294c.jpg 800X599 px
jpg  IMG_1663.jpg (161.91 KB)
39_5e350b9cf37c3.jpg 960X1280 px
jpg  IMG_2843-614x819.jpg (181.66 KB)
39_5e350c205df33.jpg 614X819 px
Posted on: 2020/2/1 5:16
Edited by datsa73 on 2020/2/2 3:12:46
'73 2 Door Sedan
Crower Stage 3 Cams/SS Valves
Forge CP Pistons/ Eagle Rods
Eaton M62 SC 10 lbs. Boost / 150hp Progressive Nitrous
Ford 8.8 Posi/4.11
love to hear the sound! any idea of the NA hp he makes?
thats
Posted on: 2020/2/2 7:10
He said somewhere around 225hp to the wheels. Which is pretty good.
Posted on: 2020/2/3 14:35
'73 2 Door Sedan
Ford 8.8 Posi/4.11
Is that the 12 valver he uses for 225hp? like the holley setup would give
better midrange torque with the equal length design. What is the body?
Its in between s13, rx7 and pontiac??? Mad tinkerers your way!
Posted on: 2020/2/4 1:22
He runs both 12 and 16 valve motors.
It's about 225hp to the wheels. That's better than a stock 16 valve 160hp on the motor alone. He's not over exaggerating as most do.
This is where the Carbureted KA got its start.
The cars are built on a s13 /240sx platform.
Posted on: 2020/2/4 23:09
'73 2 Door Sedan
Ford 8.8 Posi/4.11
250hp ate is very believable these heads
flow way more than even sr16ve engines.
2.4L 2400cc 250hp is very reliable hp.
Ive been wondering if a yota 1ar-fe crank
could fit the KA or QR blocks which both
have 89mm bores, toyota 90mm bore but its
alloy block and at its limit.
As you know the drift champion car built
by Pappadakis uses the 1AR 105mm crank to
90000rpm. The Toyota 1arfe pistons and
rods are incredible from factory.
Please if you have time ask your mad mate
if he can get the specs of the 1arfe
crank as I reckon it would be close.
KA27DE or QR27DE prob is very possible.
In your case 300cc is nothing as you run
boost but his NA build could make use of it.
Posted on: 2020/2/5 10:03
I dont think he's too concerned about the build on these KA motors. He builds these cars for specific drivers and not for himself. They want a car with a motor in it to race. 🙂
Posted on: 2020/2/7 17:39
'73 2 Door Sedan
Ford 8.8 Posi/4.11
So here's another picture of my rear oil port for the KA24DE block. It will allow oil to flow evenly throughout the block. This should avoid any attempts for another #4 rid bearing to spin.
Still waiting for my parts from the Balance Shop. A full engine Balance should get me some smooth high RPM's. 🙂
jpg  20200208_115614_copy_1008x477.jpg (181.89 KB)
39_5e4167e601f3d.jpg 1008X477 px
Posted on: 2020/2/10 14:31
'73 2 Door Sedan
Ford 8.8 Posi/4.11
So my coworker was mentioning about how his daughter took up drifting. He mention it was a 6 cylinder Lexus she was driving. I was guessing a 2JZ motor so I brought this link to show him what that motor is capable of doing.
Import Face Off Pacific 2019
The first race is a GTR.
Second race is the 240z with the 2JZ motor.
Third race I was surprised when my car came up. I pulled it off at the end.
Last race is a 510 with a turbo KA24E.
Posted on: 2020/2/14 5:34
'73 2 Door Sedan
Ford 8.8 Posi/4.11
