« 1 ... 89 90 91 (92) 93 94 95 ... 97 »
Re: Super Bee KA24DR Sedan
faster than the 510 datto by 0.07 seconds!!
also you beat the Honda which surprisingly
had a good start but you had higher trap speed?!
Some lexus/Crowns/mk2 had 1zj-fe which some prefer due
to very revvy natures can hit 10k rpm with right internals.
I know today the 2jz is king of the imports but the vg30 is
a very underrated engine that can match the Jz series.
From factory the vg30 is re-known for 800hp stock internals
for NA the now getting old VQ V6 owned by Sascha Anis built by JWT
makes 537 hp 8200rpm / 410 lb-ft most powerful NA VQ in the world.
Designed for road racing has usable 350 lb-ft at just 3,500 rpm.
https://www.enginelabs.com/engine-tech ... an-vq-series-engine-ever/
At the end of the day, carb fed supercharged KA2.4L is so crazy for
its an analog route many will not tinker with in favor of high tech ecus.
Posted on: 2020/2/14 11:26
Edited by D on 2020/2/14 12:26:11
From Snohomish, WA USA
It's all about Old School Technology.
Posted on: 2020/2/16 0:49
'73 2 Door Sedan
Crower Stage 3 Cams/SS Valves
Forge CP Pistons/ Eagle Rods
Ford 8.8/Mini Spool/4.11
Parts have been back from the balance shop for about a week but I've been busy working on jetskis and Snowmobiles. 🙂
Better get back to the car. I painted the block black again. I debated yellow. If anyone thinks I should paint it yellow, put in your 2 cents. Crower Stage 3 came and valve just waiting to be installed. 👍
jpg  20200222_181117_copy_1152x546.jpg (178.73 KB)
39_5e520366a3f27.jpg 1152X546 px
Posted on: 2020/2/23 4:51
'73 2 Door Sedan
Oldskool Red :) will be a nice contrast
but either way that KA is infernal
Posted on: 2020/2/23 5:04
Although by now the motor would be in and running but since the season does not start for another month, I've been off doing other things. I manage to put the head on, set the timing and install the timing covers today. I'll be back at it next week. I have to work this weekend.
jpg  20200227_135727_copy_410x866.jpg (193.44 KB)
39_5e59f13145886.jpg 410X866 px
Posted on: 2020/2/29 5:01
'73 2 Door Sedan
Motor ready to go in.
New Look!!!
Had to wait a week for Chris to powder coat the valve cover.
Not going to make the first race next week but no big deal. Season opener is just one crazy day. 🙂
jpg  20200312_152547_copy_400x845.jpg (188.84 KB)
39_5e6ab814a8b8a.jpg 400X845 px
jpg  20200312_152604_copy_400x845.jpg (187.73 KB)
39_5e6ab82580959.jpg 400X845 px
jpg  20200312_152714_copy_400x843.jpg (187.76 KB)
39_5e6ab82f88f23.jpg 400X843 px
jpg  20200312_152637_copy_1008x477.jpg (170.78 KB)
39_5e6ab839e63b3.jpg 1008X477 px
Posted on: 2020/3/12 22:33
'73 2 Door Sedan
New motor bolted to the Powerglide.
I spent a little time yesterday sanding the letters on the valve cover. Used a sanding block and started with 80 grit and worked my way up to 1500 wet sanding at 800 and up. Looks much better now.
I'll put everything else in today. If I have time, I'll fire it up. May run a few passes before swapping the 430 gears with the 411 just to get an idea on the new motors performance.
Race season. Is just around the corner. 👍
jpg  20200313_163551_copy_1008x477.jpg (176.03 KB)
39_5e6cfd8e76538.jpg 1008X477 px
jpg  20200313_163437_copy_1008x477.jpg (152.87 KB)
39_5e6cfd9aa126d.jpg 1008X477 px
jpg  20200313_163410_copy_400x843.jpg (162.88 KB)
39_5e6cfdae541c5.jpg 400X843 px
jpg  20200313_164407_copy_400x845.jpg (150.57 KB)
39_5e6cfdbe35372.jpg 400X845 px
jpg  20200313_122501_copy_400x845.jpg (155.34 KB)
39_5e6cff485aebc.jpg 400X845 px
Posted on: 2020/3/14 16:00
'73 2 Door Sedan
extra yellow power originally from Japan
but American tinkering for more muscle.
Posted on: 2020/3/16 7:07
Yellow for show.
Ingenuity for go.
Had the car out for a easy drive a couple of days ago.
At work now. Need to pick up for fuel this weekend.
Car ran strong and pulls.
Will run it harder next week.
jpg  IMG_20200317_173700_01_01_copy_648x486.jpg (169.41 KB)
39_5e74501fab932.jpg 648X486 px
Posted on: 2020/3/20 5:14
'73 2 Door Sedan
Hows is the rear and overall balance of the suspension?
will you be needing tubs for the rear or the car sitting
as it is does the job? Really would like to see your car
in a motoring magazine for the japanese and ever speedhunters.
on another note do you know the rod length on these motors?
Posted on: 2020/3/20 7:49
