E series v8 possible? Hacksaw, welding, brain, courage, sweat etc
Best vids on home made engines by an legend genius
v12 from L6 -take note of conrod solution for narrow crankpin!!!!
what a master to employ a Linkrod system @ 4.30min
https://www.youtube.com/watch?v=FnXUx4 ... &ab_channel=AllenMillyard
V8 from L4
https://www.youtube.com/watch?v=sjxiHL ... &ab_channel=AllenMillyard
A series would be insane but pushrods and non crossflow has its limits.
Instead the E series or even a G series head and bores could be used?
60 degree v8
eg. Carbon Steel 8mm plate welded crankcase and separate bore casing for
77mm renault sleeves housing for E16 crank and linkrods with angled cap bolts
Steel plate bore housings and wet sleeves from renault 805 sierra or similar.
3.3 litre v8 77mm bores x 88mm stroke.
too much work but what a project for a Millyard like dude into dattos
Posted on: 2021/1/14 4:17
Re: E series v8 possible? Hacksaw, welding, brain, courage, sweat etc
From Perth
Get onto it
Couple of B6 heads will cure your pushrod problems
Posted on: 2021/1/14 9:41
From Near Bundaberg QLD
Turn 2 A10's into an A20 = finally Australian street legal V8
Posted on: 2021/1/14 12:44
Thanks, Sam-U-El/Racer135
4 utes, 1.5 sedans, 2 120Y sedans, 1 C120, 1 1600 sedan, all look like or are wrecks
From Mordialloc Victoria 3195
I say "JUST DO IT D" - put all that knowledge to use.
dp
Posted on: 2021/1/14 19:51
keep it simple
From Las Vegas USA
I read Classic Motorcycle Mechanics magazine and Millyard's builds are routinely featured. Works of art.
Posted on: 2021/1/17 5:03
