Inlet manifold CAD DXF file download
From Sydney
Just wondering if anybody has the the manifold CAD files (in DXF format) laying around. Link found in our Manifold tech article is not working.
Good to see this forum is still going
Cheers
Posted on: 2021/1/26 10:08
Re: Inlet manifold CAD DXF file download
From Adelaide
I have an old dwg file of the oval 5 piece if you want that? What are you doing? what do you need?
Posted on: 2021/1/29 21:58
1200 Coupe A15E - ITB
Lamb Daiquiri - a man's cocktail!
From Sydney
That would great if you don't mind sharing. I want to inject my A15 and was hoping to get some manifolds made up.
Have you had the manifolds made up before? how did it work out?
Thanks
Posted on: 2021/2/6 22:45
From Adelaide
I have some flanges another member had cut, a couple in mild steel, one in aluminium. I also got some of my own profiles cut and started making up flanges with injector bungs. The main problem is that the ports are so close together it's really tricky to get a welding torch in between them. I'd be willing to sell them to you, I don't think I'll ever use them. I'm also happy to email the dxf if that's what you want.
Another member used a redline DCOE manifold as a starter and I just thought that's a way better solution and did the same. Bought a second hand DCOE (twin weber), added some injector bungs and made up runners and plenum to bolt on. The only thing I'd do differently is make injector bungs since the ones I bought were really thin and hard to weld to a big thick casting. I ended up having to re-machine the injector bungs since a few I'd melted the sides and they drooped.
Either was there's a fair bit of work in it.
Posted on: 2021/2/8 19:51
I also have oval port aluminium flanges out of i believe 10mm plate already laser cut. I am not going to use them any longer. They cost me around $110aud to have cut. I would be looking for that plus shipping from the states where I am now.
Posted on: 2021/2/9 15:39
Posted on: 2021/2/9 15:54
From Sydney
Thanks guys. I've just started to learn CAD and I was hoping to use the DXF file to play around. I have an A15 I will be injecting in the near future so seemed like a good way to learn.
Datsunbeginner, The flanges will work of course. If I go down that path I will contact you. Appreciate it mate
Posted on: 2021/2/11 11:55
From Perth
would be nice if they could be hosted somewhere they won't disappear ...for the future
oh and the DCOE ones too
I thought I had them ... but can't find them .. that or i did find them but don't have a proper program to open them
jpg  DCOE.jpg (48.37 KB)
527_60264c217001d.jpg 1460X929 px
jpg  OvalPort_5Piece.jpg (38.27 KB)
527_60264cc164da8.jpg 1460X382 px
Posted on: 2021/2/12 9:36
From Freo
Diamond ports Dattoman...
Posted on: 2021/2/17 9:40
A15 PSI Project Motor
'72 CB750k,
From Perth
Yeah mate
Round and oval are so yesterday
Posted on: 2021/2/18 9:51
