Off the shelf throttle cable for Keihin carbs
From Las Vegas USA
I have found an off the shelf throttle cable for those of us using Origin carbs.
Motion Pro part number 04-0231
It requires an adapter to be made for the fire wall. You'll need a 25-28mm long adapted one end for 14mm 1.50 thread and the other end 14mm 1.25 thread. After that you need to use a dremel to shape the gas pedal slightly to accommodate the cable end on the Motion Pro cable.
Prior to this I was having custom cables made.
Posted on: 2021/2/16 23:27
Re: Off the shelf throttle cable for Keihin carbs
From Sydney
Good find Tom
Posted on: 2021/2/17 2:26
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
