Welch plug replacement- cylinder head.
From Sydney
Anyone ever ever successfully replaced the welch plug in the rear of the cylinder head, without removing the head? It’s oh so tight with limited space between head and firewall.
I’m keen to hear how you went about it. Worst case scenario, the head will have to come off.
cheers.
Posted on: 2021/3/6 10:29
Edited by benny on 2021/3/6 11:50:17
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
Re: Welch plug replacement- cylinder head.
From Sydney , NSW
No good news for you I think Benny .... The old one will be painful to remove as it will most likely be lightly corroded in and the new one is an interference fit which has to be set straight as you can imagine. Head gasket is cheaper than the anger management therapy that will be required otherwise!
Posted on: 2021/3/7 8:19
All torque, no traction
A division of "My mate's ....." engineering
From Las Vegas USA
Only had to do it once; I too pulled the head, I left the intake & exhaust attached.
Posted on: 2021/3/8 4:47
From Melbourne AUS
ive done it once but had the gearbox out which made it possible from underneath, still had to swear at it though
Posted on: 2021/3/9 2:43
1973 B110 A12
From Sydney
Thanks for the replies, head came off. Probably best as upon inspection the valve stem seals were severely worn or missing. Good colour in the combustion chamber indicator good burn. Closer look at block under the headers, reveal the other Welch plugs were shot. It would have been a matter of time. Only one left to replace to the 50mm plug behind the flywheel.
Posted on: 2021/3/10 7:44
1970 KB10 Coupe
S13 caliper b...
