« 1 ... 91 92 93 (94) 95 96 97 »
Re: Super Bee KA24DR Sedan
From Snohomish, WA USA
Been at the track twice so far this year. Car has been running great but my times are still not improved. 4.11 gears with 26 inch tires. I have decided to not quite go back to the 4.30 gears. I use to run the 1/8th mile with the 4.30's and 23 inch tire so im going to try the 23's with the 4.11's.
The 23's have a wider tread anyways which should help if i plan to bump up the nitrous a bit. 👍
Posted on: 2021/6/21 15:34
'73 2 Door Sedan
Crower Stage 3 Cams/SS Valves
Forge CP Pistons/ Eagle Rods
Ford 8.8/Mini Spool/4.11
Are you hitting the peak RPM at the finish line? Maybe the HP peaks at a slightly lower RPM
Posted on: 2021/6/23 6:55
Peaks around 7k and that where I shift and when I hit the 1/4 mile. Sticking with the 4.11's.
Not much racing this year but was able to make it out to Import Face Off in Kent, WA. Car runs a 11.50 consistently. Luckily they had a 11.50 index class.
I'm in!!!
Took 1st Place. That was a no brainer. 🙂
Opportunities for some more races in September and early October so we'll see.
jpg  20210829_171029_copy_2184x4608.jpg (189.74 KB)
39_612fbffc4cb63.jpg 2184X4608 px
Posted on: 2021/9/1 19:03
'73 2 Door Sedan
From MOOROODUC. Victoria
Congrats!
Posted on: 2021/9/5 1:46
Thanks.
I can honestly say its been a long road tuning these 38 carbs. 🙂
Posted on: 2021/9/5 16:55
'73 2 Door Sedan
Well the racing off season has been really easy this year. No engine rebuild for the Datsun. Of course there has been multi rebuilds, just not the car.
Car ran great last year. In the end I just needed more fuel on the nitrous. 👍
Season will start late March and an oil change is all that is needed.
Plan on giving it more juice. I need to break into the 10's. 🙂
Posted on: 2022/1/29 19:18
'73 2 Door Sedan
Been out a few times this year. Been racing for Team Mopar although there's some Chevy and Ford in this car. No Mopar..... just the sticker. 🙂
Import Face Off is my favorite.👍
Took second place in the 11.50 Index class. No trophy, just a purse payout. 🙂
Won It last year but a guy in a 10 sec VW Bug decided to sandbag me and take the trophy.
I roll Balls Out!!!
Anyways what can you do. 🙂
jpg  Screenshot_20220829-073538_Facebook.jpg (162.35 KB)
39_630cde24e9a71.jpg 1006X618 px
jpg  IMG_20220828_203353_copy_683x929_copy_662x900.jpg (159.16 KB)
39_630cde390e344.jpg 662X900 px
Posted on: 2022/8/29 16:47
'73 2 Door Sedan
wow 11 seconds. From a KA24DE truck motor. Good on ya!
Posted on: 2022/8/29 21:56
Dave,
It's actually a S14 out of a 240sx. Slightly different motor than the KA they put in the Nissan Frontier.
I believe stock is 30 more HP. 👍
Posted on: 2022/8/30 5:30
'73 2 Door Sedan
A couple of changes this year to the car. I decided to get rid of the front steel wheels and go with an aluminum wheel with 3.5 inch skinny's in the front and a mini spool in the the rear. Should improve times. We hope. 🙂
jpg  Screenshot_20230314_202954_Photos_copy_730x337.jpg (196.44 KB)
39_64112e5ff2da1.jpg 730X337 px
jpg  20230312_143626_copy_654x368.jpg (198.90 KB)
39_64112f20dfc99.jpg 654X368 px
jpg  20230312_130942_copy_333x592.jpg (199.38 KB)
39_64112f59b18a9.jpg 333X592 px
Posted on: 2023/3/15 2:36
'73 2 Door Sedan
