Thoughts on using a radiator flush product?
From South Africa, Bloemfontein
Hi all
My 1200GX was re cored many years ago. I need to replace coolant as it has been using the current coolant for many years now. Coolant is still green and I can see the fin holes inside the radiator through the green coolant. My question. Due to the age of the car, must I maybe use a coolant flush product to clean out the pores in the block and the intake manifold where all the radiator water circulates?
I am between 2 worlds at this stage. One side I just want to flush with a hosepipe and normal tap water and replace with distilled water and coolant mix and on the other side I want to use a flush to maybe get rid of all the scaling that might be present inside the passages due to age of the engine. I am however concerned about stuff getting loose and clogging a water port with my luck.
What are your thoughts?
Posted on: 2021/6/23 8:28
Edited by 1200GXman on 2021/6/23 10:01:47
1977 Datsun 1200GX
Re: Thoughts on using a radiator flush product?
quality coolant can last many years (my Forester has 16 year old coolant and is very clean inside)
if it looks clear now, i would use tap water to flush out the system and the block, then fill with distilled water/coolant mixture
You might see some rust flakes come out of the engine block drain plug hole, that is common with iron blocks
see Coolant Replacement
Posted on: 2021/6/23 10:42
Wow. thanks for the link. never knew about this bolt. I doubt it was ever removed in the car's lifetime.
I hope I will get it loose.
Chances are it is because it is possibly a aluminum block.
Posted on: 2021/6/23 12:25
1977 Datsun 1200GX
