77mm A12 block
For sale at auction
https://aucview.aucfan.com/yahoo/k493441051
Seller says it's an A15 and indeed the engine stamp says 'A15' however the 5 is off kilter
H85 is the B310 Sunny 1978-1982 A12 block with 73mm bore. A15 is 76mm. Can these later A12s be bored out to 77mm? I wonder if an A15 crank would fit in there
After thinking about it I marked up some of the photos to show the identifying features. It has a 77mm bore and is marked 'A15' but otherwise is a short-deck A12 block
jpg  77 mm bore.jpg (77.85 KB)
174_6142880d4051d.jpg 1200X900 px
jpg  identifying features - Block Code H85, low deck height, ID pad below top of block.jpg (129.32 KB)
174_614288239ae7e.jpg 1200X898 px
jpg  Left with Non-Equally spaced welsh plugs.jpg (111.48 KB)
174_6142885150408.jpg 1200X900 px
jpg  Bottom - would an A15 crank fit.jpg (130.13 KB)
174_6142886c66828.jpg 1200X900 px
jpg  cylinder walls from above.jpg (113.58 KB)
174_6142888ad589f.jpg 1200X898 px
jpg  cylinder walls from below.jpg (94.02 KB)
174_614288956cd46.jpg 1200X898 px
jpg  Left side foreward welch plug, motor mount studs.jpg (116.03 KB)
174_614288b4dafe3.jpg 1200X900 px
jpg  Top.jpg (123.21 KB)
174_614288c111d7f.jpg 1200X900 px
jpg  Right.jpg (132.66 KB)
174_614288ce2b51a.jpg 1200X900 px
Posted on: 2021/9/16 0:59
Re: 77mm A12 block
nice find but also there were low height A13 engines with 76mm bores and 70mm crank as well as tall block A13 with 77mm strokes last I recall. Maybe they used an A13 short height block? Datsun peeps are spoilt for A series combos.
Posted on: 2021/9/17 12:26
